Page 2 of 2 FirstFirst 12
Results 31 to 38 of 38
Thread: TAMIYA Thrust Ball Bearing
  1. #31
    ON
    9,401
    Quote Originally Posted by longballlumber View Post
    Pete,
    I have been running a .150 square/square set up in my PT Stealth for 3-4 years now.
    How do you do lube jobs on a contained drive like that? How often?
  2. #32
    MI
    3,117
    *Flip the boat over loosen 2 set screws in the ferrule
    *pull the stub shaft out far enough to remove ferrule
    *pull the flex shaft from the rear of the boat.
    I grease as I would normally 2-3 runs.
  3. #33
    ON
    9,401
    Cool, thanks Mike.
  4. #34
    Oct 2009
    FR
    2,096
    Diameter difference between the 3/16" shaft and the 5mm TAMIYA Thrust ball bearing is less than 0,25 mm, no problem (0,009").
  5. #35
    Dec 2009
    LO
    30
    Quote Originally Posted by Alfa Spirit View Post
    Really ???
    Have you ever tried before writing such nonsense?
    I do not think so !
    Give us a real test, on a boat runs off a shelf, and then you can say that with 0.25mm, you can run without problem.
    Your boats never left the shelf where they take dust.
    Oh, no, they move when you take picture. Sorry...
  6. #36
    Feb 2008
    GB
    2,729
    Easy Tiger!
  7. #37
    Aug 2012
    ny
    1,359
    Run em on all my boats, never a prob.
    We call ourselves the "Q"
  8. #38
    Oct 2007
    WA
    90
    I don’t think you need one,less you worry about the End bell coming off. Personally I think there a waste time & money and set up
