Page 8 of 15 FirstFirst ... 678910 ... LastLast
Results 211 to 240 of 432
Thread: ML Boatworks RSX380 Outrigger! My first FE wood kit build...
  1. #211
    Jul 2018
    WI
    1,015
    Here you can see the two epoxy formed ride pad bays.
    And a close up shot...
  2. #212
    Jun 2015
    Mt
    109
    Don't forget flotation, just in case.
  3. #213
    Jul 2018
    WI
    1,015
    Quote Originally Posted by bhorowitz View Post
    Yes. Thank you. I just remembered I need to do that actually...
  4. #214
    Apr 2017
    QL
    1,038
    very nice.
  5. #215
    Jul 2018
    WI
    1,015
    Has anyone tried spray foam for flotation?
    They use it in 1/1 boats. My local hardware store has low expansion, weatherproof spray foam I'm thinking about trying.
  6. #216
    Jul 2018
    WI
    1,015
    Here's a link to 1/4" teflon for epoxy forming carbon fiber...
    https://rover.ebay.com/rover/0/0/0?m...2F143012082779
  7. #217
    Jul 2018
    WI
    1,015
    Testing the expansion rate of the spray foam...
    When I squeeze the epoxy cup, I feel no pressure on the sides. The pressure is escaping upwards.
  8. #218
    Jul 2018
    WI
    1,015
    A mod to the PVC pipe clamps. Zip tying polyurethane strips to them for grip so they don't slide around, and so they don't mark the birch plywood sheeting...
  9. #219
    Jul 2018
    WI
    1,015
    Yes, I epoxied the sponson tubes.
    Even tho I know the expansion rate, I still overfilled the sponsons. Trust that the foam will fill them...
  10. #220
    Jul 2018
    WI
    1,015
    They must sit overnight. It takes that long to completely cure. I checked this out in the epoxy cup. Do not bump them, the foam will collapse and lose air bubbles.
    This is the final expansion the next day...
  11. #221
    Jul 2018
    WI
    1,015
    The foam trims flush easily with a serrated knife...
  12. #222
    Jul 2018
    WI
    1,015
    Setting up for epoxying the top deck...
  13. #223
    Jul 2018
    WI
    1,015
    One sponson done and curing!
  14. #224
    Jun 2015
    Mt
    109
    Sammy,
    Is that foam fairly light? Some of that stuff that I've seen is pretty dense and heavy.
    Bob
  15. #225
    Jul 2018
    WI
    1,015
    Sammy,
    Bob
    Very airy and light
  16. #226
    Jul 2018
    WI
    1,015
    Keeping the tape on the right sponson, at least overnight. Pulled the clamps, the left sponson sheeting is on.
    I must say, there's a lot of techniques for sections of a wood boat build to figure out. Mike says the sponson top sheeting is the hardest part of the build...
    It's amazing how they are pumping out all those nice quality RTR's.
    They must factor the time and cost to build into the construction/assembly part of the design. Yet they have a nice finished look to them along with great performance. Smh...
  17. #227
    Jul 2018
    WI
    1,015
    Pulled the tape, trimmed the top sheeting. I succeeded in getting all the epoxy joints tight...
  18. #228
    Oct 2018
    Az
    38
    Very nice,
    I have power tool's, it will fit
  19. #229
    Jul 2018
    WI
    1,015
    I asked about spray foam, no one responded.
    Here's my very scientific comparison between four types of foam...
  20. #230
    Jul 2018
    WI
    1,015
    White foam, very soft and light...
  21. #231
    Jul 2018
    WI
    1,015
    Packing peanuts, basically just air...
  22. #232
    Jul 2018
    WI
    1,015
    Spray foam, the heaviest in my study. Structurally the strongest, not really that much heavier. Not enough to be a concern...
  23. #233
    Jul 2018
    WI
    1,015
    Pipe insulation. Firmer and more dense than the white foam. Right in the middle for weight...
  24. #234
    Jul 2018
    WI
    1,015
    Can anyone tell me if the inside sponson to sponson measurement of 14-7/8" given in the manual applies to the RSX380?
    The manual is for all three riggers, are they all the same?
    Scaling these drawings, they don't look to be the same...
  25. #235
    Jul 2018
    WI
    1,015
    I bought a Map torch and some good silver solder. The real stuff, 45% silver brazing alloy...
  26. #236
    Jul 2018
    WI
    1,015
    And some 1/16" galvanized cable.
    The copper tabs are cut out from split open and flattened copper tubing...
  27. #237
    Jul 2018
    WI
    1,015
    I drilled the copper tabs and formed them around the cable. The cable is folded over about 3/8" from the end and silver soldered in...
  28. #238
    Jul 2018
    WI
    1,015
    I'll run the cable on the back side of the sponson rods and put shrink tubing over the cable and rods at final assembly. The copper tabs will be bolted on with the screws retaining the sponsons.
    I'm putting a cable on the front and back rods. That's 1/8" OD brass tubing going thru the tub.
    I don't think I'd put a rigger in the water without safety cables to keep the sponsons attached to the tub...
  29. #239
    Jun 2015
    Mt
    109
    Sammy,
    What are the cables for, Just safety to keep from losing the tub if you break the booms?
    Bob
  30. #240
    Jul 2018
    WI
    1,015
    Sammy,
    Bob
    Yes, can't live with the thought of losing the tub...
