Page 7 of 15 FirstFirst ... 56789 ... LastLast
Results 181 to 210 of 432
Thread: ML Boatworks RSX380 Outrigger! My first FE wood kit build...
  1. #181
    Jul 2018
    WI
    1,015
    Then I removed my servo tray.
    It weighs 1.05 ounces and the CG moved about half the thickness of the spruce strip. An eighth of an inch...
    Interesting? It sure is too me...
  2. #182
    Jul 2018
    WI
    1,015
    The question is, what does this mean, real world?
    Other words, what difference in handling would moving the CG an 1/8" make? Would you even notice the difference? I don't know the answer to that...
    I can figure this much tho. From the CG point to the center of the back bay measures 17", and it's 15" to the tips of the sponsons.
    That a 1.13/1 ratio.
    For an ounce heavy in the back you would need 1.13 ounces in the front.
    So weight in the back is something to avoid.
    It's a bigger deal with airplanes, more like a 3/1 ratio.
    This should balance nicely...
  3. #183
    Apr 2017
    QL
    1,038
    I doubt very much you will notice any difference by moving the c.o.g. back or forward even by 1 inch each way.
  4. #184
    Sep 2012
    Tg
    1,441
    The position of your turn fin in relation to the CG is more important.
  5. #185
    Jul 2018
    WI
    1,015
    I share this because I think it worked out quite well. Maybe someone else building a rigger can use this.
    You have to buy two, to get eight pads(or cut more pads from the scrap). They are $10.99 each, I got the carbon fiber ones... https://www.offshoreelectrics.com/pr...prod=ose-80525
    The pictures tell the story...
  6. #186
    Jul 2018
    WI
    1,015
    I got my battery straps figured out...
    https://youtu.be/pb5P7KMyRgg
  7. #187
    Apr 2017
    QL
    1,038
    well done , your doing a great build .
  8. #188
    Jul 2018
    WI
    1,015
    Quote Originally Posted by rol243 View Post
    Thank you...
  9. #189
    Jul 2018
    WI
    1,015
    Mounting the Spearfish 200A ESC is another challenge with this build. It's huge! After studying this for quite awhile, I figured this was my only solution.
    Although I removed the top cross section of the middle former, the braces under the ESC mount more than replaces it for strength.
    The end result worked out to my satisfaction...
  10. #190
    Jul 2018
    WI
    1,015
    Still have to add velcro under the ESC.
    In the second picture, the top of the former is now removed...
  11. #191
    Jul 2018
    WI
    1,015
    Here's an overall look with batteries in place.
    Everything fits under the cowling...
  12. #192
    Jul 2018
    WI
    1,015
    I love the way this kit goes together...
    Sheeting the rear sponson shoes with 1/32" birch plywood. I made many more small epoxy mixes, carefully spread with a screwdriver on all the formers and basswood strips.
    Since tacking the main tub and sponsons together with CA, I've used epoxy throughout this build.
    More time consuming but worth the strength...
  13. #193
    Jul 2018
    WI
    1,015
    Bottom ride pads forming nicely in one continuous piece up the leading angle...
  14. #194
    Jul 2018
    WI
    1,015
    The top and bottom sheeting overlaps the side sheeting.
  15. #195
    Jul 2018
    WI
    1,015
    Stripped the hardware and electronics, sanding the tub before sealing with epoxy...
  16. #196
    Jul 2018
    WI
    1,015
    Shaping the nose block and 1/4 round. Sanding edges and bedding the rear sponson shoes...
  17. #197
    Jun 2015
    Mt
    109
    Sammy,
    You can build a boat for me anytime. Beautiful job, and great job with the build log.
    Bob
  18. #198
    Jul 2018
    WI
    1,015
    Quote Originally Posted by bhorowitz View Post
    Sammy,
    Bob
    Thanks for the positive feedback Bob! It's slow going tho, but that's how I like to build. I enjoy the journey and eventually I'll get there...
  19. #199
    Jul 2018
    WI
    1,015
    The inside of the tub is epoxied. The "bend the acid brush" tip was in use for all the hard to reach corners...
  20. #200
    Jul 2018
    WI
    1,015
    Here's why I save scrap. Perfect use for titanium, it won't rust and I'll never strip these threads.
    On the down side, I wrecked a brand new Dewalt hacksaw blade.
    The chamfers and radius are clearance for the epoxy joints inside the sponson. I nested the titanium block in hardwood...
  21. #201
    Jul 2018
    WI
    1,015
    The hardwood gives the epoxy better bite than the titanium alone and spreads the load forces...
  22. #202
    Apr 2017
    QL
    1,038
    coming along very nicely.
  23. #203
    Jul 2018
    WI
    1,015
    I'm also epoxy forming the carbon fiber in the sponsons. Just the two ride pad bays.
    I feel that this is similar to vacuum forming. Not exactly the same, I know. But it forces the epoxy thru the CF and gets a better bond to the wood.
    I'm doing it slightly different than from how I did the tub. I'm not trimming the CF inside the sponsons. I can get away with doing it this way working with smaller pieces. Plus it will be covered up. This is only for strength. The ride pads probably take more pounding than anywhere else on a rigger.
    I'll roll some pictures...
  24. #204
    Jul 2018
    WI
    1,015
    I placed the CF in there and pressed it down with the teflon to tuck in the corners.
    Then I removed the teflon, poured in some slightly thinned epoxy, just enough so it squeezed out around the top when I pressed in the teflon again.
  25. #205
    Jul 2018
    WI
    1,015
    After weighting it down(on the screws) and curing, I removed the teflon by pulling on the screws...
  26. #206
    Apr 2017
    QL
    1,038
    excellent work, keep it going.
  27. #207
    Jul 2018
    WI
    1,015
    It's a little hard to take pictures of, but here's some shots of the final result...
  28. #208
    Jul 2018
    WI
    1,015
    I really appreciate that. Thanks...
  29. #209
    Jul 2018
    WI
    1,015
    I read in another thread about guys using Klass Kote epoxy paint. I found it on Ebay.
    Here's the link to Part A, the colored part... https://rover.ebay.com/rover/0/0/0?m...2F152029025775
    This seller also has the Part B catalyst and the reducer for thinning.
    I placed my order by adding to basket, he combines shipping. Great seller, I contacted him, fast response...
    Prior to this, the only other two part epoxy paint I could find was Coloredepoxies on Amazon for $78.16 per color. This is a 2/1 mix, you have to buy 3 quarts minimum.
    Here's my total for white, orange, catalyst and the reducer...
  30. #210
    Jul 2018
    WI
    1,015
    I have a daytime job too, and I've been pounding the OT.
    This part of the build is finished tho...
