Page 10 of 15 FirstFirst ... 89101112 ... LastLast
Results 271 to 300 of 429
Thread: ML Boatworks RSX380 Outrigger! My first FE wood kit build...
  1. #271
    Jul 2018
    WI
    1,013
    Thanks hey for the feedback. Great insight on the dyhedral feature of Mike's design. I will take that bushing out and clean off the loctite...
  2. #272
    Jul 2018
    WI
    1,013
    I have all my colors layed down. As far as what I'm painting and what stays natural.
    Next is canopy, turquoise pinstripes and lettering. The lettering will be done in turquoise and white.
  3. #273
    Jul 2018
    WI
    1,013
    With this two part Klass Kote epoxy paint, it can be re-coated in 24 hours. But it takes 4 days to a week to fully cure.
    I've taped it for the next color in 24 hours without a problem.
    I'll probably let all this sit for awhile. Then I can handle it without concern for the rest of the painting.
  4. #274
    ON
    9,402
    I want to thank you for this highly detailed build. My 310 is built but not rigged and finished.
    Paul helped me with my build, specially the sponsons. Hopefully they are paralel and straight. I will have to check them when back at apartment. I think mine are o.k. thanks to Paul.
    The KlassKote info was so welcomed since I have some stored away that I bought in 2014, hopefully it's still usable, you think? Since I don't have a compressor to spray, your brush technique is very welcomed!!! I will give it a try. If it works I can get some orange for my rig. I just have white now.
    Thank you so much. I will be reading it over a few more times.
  5. #275
    Jul 2018
    WI
    1,013
    Your welcome. It's good to share experience and ideas, we all benefit when that happens. I learn so much this way too. Paul has also been a great help to me...
    I have a little bit of white K & B Super Poxy paint that I used for many years(wasn't enough left for this project and I had no other colors). So I bet your 2014 Klass Kote is still good. Test a small mix to see if it hardens.
    Here's a tip on brushing the Klass Kote. It says to let it activate in the cup for 30 minutes before using. I found it would not flow as well towards the end because brushing takes longer. I've been getting great results waiting 20 minutes, then I start using it. It flows better and hardens the same.
    I'm using these 1" wide & 1/2" wide bristle brushes from my hardware store. They are around a dollar each. They work great, then I toss them...
  6. #276
    Jul 2018
    WI
    1,013
    I did get this turquoise pinstripe on today. The color scheme is starting to come together...
  7. #277
    ON
    9,402
    Very nice, thanks again!
  8. #278
    Jul 2018
    WI
    1,013
    I said in post #273 I would let the paint cure before handling it to finish up.
    But with careful handling(the epoxy paint will get marked with fingerprints unless you wait 24 hours), I did get the turquoise pinstripe on the tub.
    Then I realized I had lettering to do on the sponsons, which are cured already...
  9. #279
    Jul 2018
    WI
    1,013
    And it gets even more tedious. The smaller white "Boatworks" lettering will be done with white paint.
    I got the tape cut out for one side.
    One more to go...
  10. #280
    Jul 2018
    WI
    1,013
    There's a nice quality look to painted stripes and lettering. Something you don't get with stickers.
    Here's some pictures that tell the story about how I did it.
    I cut this stack out with a #11 exacto knife...
  11. #281
    Jul 2018
    WI
    1,013
    Here's what's the stack consists of.
    The clear is transfer paper from Amazon...
    12" X 10ft Clear Transfer Paper... https://www.amazon.com/dp/B06XY8CLCG?ref=yo_pop_ma_swf
    The small pieces are from inside the letters...
  12. #282
    Jul 2018
    WI
    1,013
    The transfer paper goes sticky side to sticky side of the low stick blue tape. I cut thru my computer printed letters and the blue tape and transfer paper.
    The stack is taped to a sheet of paper folded in half. Makes for a nice clean cut...
  13. #283
    Jul 2018
    WI
    1,013
    Separating the transfer paper from the inside pieces...
  14. #284
    Jul 2018
    WI
    1,013
    And place inside the letters...
    EDIT: Grrr, that annoying upside down thing!
  15. #285
    Jul 2018
    WI
    1,013
    I used a cut down 1" sponge brush and dabbed the paint on these small letters...
  16. #286
    Jul 2018
    WI
    1,013
    That pretty much completes my overall paint scheme...Sent from my SM-G950U1 using Tapatalk
  17. #287
    Oct 2018
    Az
    38
    Looks good,
    I have power tool's, it will fit
  18. #288
    ON
    9,402
    Have you or anyone tried these with Klass Kote?
    https://www.amazon.com/Preval-267-Sp...SIN=B0000AY19M
  19. #289
    Jul 2018
    WI
    1,013
    I have not. Looks interesting tho.
  20. #290
    Jul 2018
    WI
    1,013
    Quote Originally Posted by oldbikerarlo View Post
    Looks good,
    Thank you...
  21. #291
    Oct 2018
    Az
    38
    I have used the Pre-val with the K&B epoxy paints, back in the 80's, worked real well.
    We used them at work also, to touch up aircraft parts, after repair.
  22. #292
    Jul 2018
    WI
    1,013
    Canopy cut to fit and installing latches...
  23. #293
    Jul 2018
    WI
    1,013
    Thanks for this feedback. Great to hear from someone who's used this. Looked too good to be true, especially for the price. Simpler than setting up and cleaning my air brush too. I for one plan on trying this at some point...
  24. #294
    Jul 2018
    WI
    1,013
    Here are some tips for using Klass Kote on the fiberglass canopy and back hatch cover.
    Since it's epoxy paint, I did not use primer.
    I lightly sanded a cross hatch pattern to skuff the gel coat. Then wiped it with the Klass Kote reducer.
    Here's how the fiberglass back hatch cover turned out...
  25. #295
    Jul 2018
    WI
    1,013
    Here's the canopy lightly sanded and wiped with the reducer...
  26. #296
    Jul 2018
    WI
    1,013
    The fiberglass is a little bit more of a struggle to paint with a brush than wood.
    What I've been doing is brush on a coat and let it flash off. Doesn't take long at all to flash off. Wait maybe five minutes.
    On this first coat I'm not laying it down heavy, or worrying about bare streaks or brush marks.
    Then lay down the second coat. Now it flows and covers nicer.
    On wood I was brushing one full coat, keep it flowing and keep moving. It seems to cover better and doesn't leave bare streaks...
  27. #297
    Jul 2018
    WI
    1,013
    Here are close up(6"away) and stand off(2'away) shots of my brushed finish. Not perfect, but certainly good enough.
    It does flatten some more after first brushing it on until it sets. This is cured over night so it's the final finish.
    The gloss and overall appearance is beautiful...
  28. #298
    ON
    9,402
    Very nice! After a week or so let us know how flexible the paint is.
  29. #299
    Jul 2018
    WI
    1,013
    Cutting out lettering one more time.
    Taping the canopy for the white at the bottom around the orange and the RSX380 lettering...
  30. #300
    Jul 2018
    WI
    1,013
    That should do it. The finished paint scheme...
