Results 1 to 8 of 8
Thread: 52.4 mph sv
    Dec 2008
    Vi
    409
    Default 52.4 mph sv
    Finally cracked the 50mph barrier or as us Aussies say 80km mark. Running an 8XL with an ETTI 150amp speedy 2 x 2s 25c 5000mah lipos. First run with CF 45mm prop 47.6 mph . then 2nd run , ran a Prather B230 & gps 52.4 mph .Dont know how that dude cracked 58.4mph ,ive tried the same set up and cant get close !!!1 Every thing ran cool no heat issus , running 2x SV27 silicon water jackets on the 540XL motor kept it nice & cool ....
    Apr 2008
    Tasmania
    3,060
    Well done Scoota. That is a very good speed.
    Several boats in various stages of destruction
    Aug 2008
    478
    Quote Originally Posted by scoota View Post
    Bat temp. and good lipos. I ran low 50's a few times and thought something was wrong you could tell it was off just by sound. I did that a couple times at the end of the day, and it left me wondering. Then i had time to run again after a low 50ish run i charged the batteries up and warmed them up some more and ran a high 57.
    ma
    8,693
    Anywhere in the 50's is boogieing! good job!!!!
    Steven Vaccaro
    Aug 2008
    478
    Its also a plane waiting to take flight
    Cool
    Adding 12-18 ounces of lead at the CG will keep the model on the water and make it less prone to take off. Sometimes you go faster by adding weight.
    Dec 2008
    Vi
    409
    Thanks guys might try adding some weight i found my self backing off a lot cause it was unstable at that speed !! as for the batteries im running flight powers EVO25 V-Powers 4900mah & Intellect 5000mah lipos witch i warm before running ....
    Jan 2009
    VI
    147
    Thumbs up Sv 27
    Scoota,
    I see your in Australia, me also, I have just ordered a SV 27, and a couple of 2 S lipo's for it, do you charge your packs as one, ie, balance all 4 cells?
    I am looking at chargers and are just a bit unsure of how to wire the balance lead.
