Page 1 of 2 12 LastLast
Results 1 to 30 of 36
Thread: New Twin Cheetah build
    Mar 2014
    551
    Default New Twin Cheetah build
    Transom reinforced with two layers of 1.5mm coremat, hard angles filled with thickend epoxy, all seams under the deck have been reinforced with 4” CF, inlay done. Sponson nose filled with epoxy. Motor mounts,servo
    Mount and stuffing tube supports done. 8AB8B8EF-271C-45A5-8F58-2BA59B91909C.jpg8B432B9E-9BCB-424C-95AA-4F7002B7DD05.jpg2F51350A-D4CF-4928-94B2-7E5068505554.jpg38350C97-C879-4579-9C1A-C66FF2E9CED1.jpg
    Jul 2015
    701
    Great start
    Nov 2008
    Ql
    3,169
    Great start indeed.
    The hull seems to have anti gravity properties. An unfair advantage, methinks.
    But seriously, looking forward to the progress on this build.
    We have a few Cheetahs racing at our club. Not many twins though.
    Any ideas on motors & props at this stage?
    Mar 2014
    551
    Default Hardware
    ESC. Seaking 180 V2
    Motors 4050 2310
    Stingers MTC
    Rudder Speedmaster
    Servo low profile Sevox
    Props 447 2 blade by Andy Brown
    No spark connectors from OSE
    I opened up the water lines in the rudder as much as possible, I also bought the cooling jacket that would be for the 4060 TP it fits perfect on my 4050. Trying to do what ever I can to make it run cooler.
    66748D23-D226-4923-8AAC-229005781428.jpgF593C58D-86D9-48E5-A8D0-F7F5317F437E.jpg4204EB94-D7CC-4946-B7FD-403D05A1C551.jpgF1C5227B-9CC1-47CF-8C79-CCB329C72522.jpg
    Jul 2015
    701
    Does that Coremat actually add that much rigidity to the hull?
    Mar 2014
    551
    It does once it’s soaked with epoxy and dry. The area were the stingers will be mounted are about 1/4 thick and it’s hard, Some use a piece of CF and that’s fine to
    2,726
    Quote Originally Posted by Prodrvr View Post
    If it is used as a core, to space 2 materials with high tensile strength appart, then yes hugely.
    As it has a very high compressive strength it actually does better in areas with bolts passing through it, than more modern cores that offer much better stiffness to weight ratios.
    With only one side of it covered, not so much, it has added 3mm of resin on top which will certainly give extra stiffness, but it will be a fraction of the stiffness that would be gained for the same weight, by using 2mm coremat and putting a few layers of glass over it.
    Jul 2015
    701
    Oh ok. What I do is where the rudder and drives are mounted, I fit a piece of 3mm cf sheet and epoxy it in.
    Nov 2008
    Ql
    3,169
    I guess I'm old school;
    I epoxy in a piece of 3mm or 4mm aluminium plate. Then drill & tap the hardware on. No need to fiddle about in confined spaces with nuts & washers.
    Jul 2015
    701
    Quote Originally Posted by 785boats View Post
    How big of a piece? That sounds heavy.
    Nov 2008
    Ql
    3,169
    Heavy? No mate.
    The same size pieces that you would fit in carbon sheet for the mounting of stingers , struts or rudders in a cat.
    Those motors have the capability of delivering 6hp constant or 13hp max in total. Do you really think they will notice a couple of grams of aluminium?
    Absolutely not in my experience.
    I do the same for the hardware & turnfins on riggers & hydroplanes. Never an issue.
    Jul 2015
    701
    Very good
    Mar 2014
    551
    2F538F7C-4C74-45E4-BE32-8D8A8257F099.jpgTP vs HRC cooling Jackets, HRC jacket should be more efficient in cooling the motors
    Mar 2014
    551
    412502DA-0951-4FE3-AF66-C97DC970D573.jpgAnother piece of the puzzle arrived
    Mar 2014
    551
    4C23B379-175E-47B4-8EB6-C42A8A49FFEB.jpgNew 447 props Sharpened and Balanced by Andy Brown
    Nov 2017
    11
    This is a awesome build. I have a carbon fiber cheetah that I’m starting to collect all the parts for now to do a twin build. I have a question. Where did you get the carbon fiber motor mounts and the flex shaft tube supports from? That’s what I’m looking for to use in my build. Thanks
    Mar 2014
    551
    I had a OSE member, tickeman (Scott) make them for me PM him
    Or you can go to Facebook and look him up at Scottski Racing
    Aug 2018
    Ky
    176
    Where did you get the stingers?
    Nov 2017
    11
    Awesome. Thank you. And ya I second on where can I find some stingers like that.
    Mar 2014
    551
    The stingers came from MHZ Powerboats in Germany great company to deal with.
    Mar 2014
    551
    Mar 2014
    551
    6221DD70-1B05-4342-9A44-9334F1CCC33E.jpg[ATTACH=CONFIG]162513[/ATTACHWater lines done. I have two like new SPC 4s 5000m for the Cheetah. They weigh 16oz each they r lighter than the Revo and Turnage.
    7,629
    Did you get the SPC packs recently?
    Mar 2014
    551
    No, I got them before they stoped seling them
    7,629
    Quote Originally Posted by royalcasa View Post
    Ahhh, ok thanks.
    Mar 2014
    551
    Feb 2017
    na
    726
    Nov 2017
    11
    That’s a awesome build !!! I have a brand new carbon fiber cheetah that has never been drilled. If I didn’t have another boat I was building I would build it. But for now I’m going to sell it to compleat my current twin build
    Mar 2014
    551
    Mar 2014
    551
    Quote Originally Posted by Tsoltero19 View Post
    Thank you
    What r you building love to see it. I like this hull so much that I was thinking of getting a CF Cheetah from MarineFe
