Results 1 to 4 of 4
Thread: What would you use a 2848 3900k motor for?
Hybrid View
    Dec 2016
    BC
    17
    Default What would you use a 2848 3900k motor for?
    As the title says , what could you do with this motor? In thinking something like a 22inch hydro on 2-3s as a saw boat. I've had this motor in a 22inch catamaran but the crappy plastic hull has micro cracks all over it. Wasn't really happy with the handling , so much torque roll. What would you guys recommend for this motor?
    Mar 2017
    VI
    371
    A small boat in the 21 to 22 inches range.
    And a x430 prop on 2s.
    Oct 2009
    FR
    2,096
    This 23'' catamaran, 2S or 3S
    Mar 2017
    VI
    371
    3s or 4s using a 35mm prop.
    If you want to use 3s a kV around 3000 to around 3400.
    4s 2200 to 2500kv same 35mm prop.
    The 4s setup will have better runtime. Maybe a slight increase in speed over the 3s setup.
    A 2860 leopard or something like it for the motor. Those 2860 motors are efficient with props in the 35mm range.
