Page 2 of 2 FirstFirst 12
Results 31 to 41 of 41
Thread: abs repair/ receiver pack
  1. #31
    Ga
    5,267
    Quote Originally Posted by Mich. Maniac View Post
    WOW! that pic of your 4th grade pic is on a couple billboards in my town for a real-estate company! thats funny stuff
    Whats up with that????
    Yankees, you can't trust them. The real estate co.has obviously been thumbing through the year books from Mayfeild Elem.:rolleyes:
    I lived in Lapeer Mich. for most of my childhood.:)
    Doug
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
  2. #32
    PA
    505
    Wow thats looks fubar! Have you had any luck fixing it?
    Ken
  3. #33
    May 2007
    co
    1,973
    Talking
    I have made some progress this last couple of days!! I roughed up the inside of the hole with a sanding drum, cleaned it with soap and water, then used a wax&grease remover to remove any oils. I used a shaped piece of pink foam, coated in waterproof epoxy, I also coated the inside of the damaged area in epoxy then inserted the foam. Then I took some 3 ounce hi power rocketry grade "glass" cloth and inserted it between the abs and the foam working epoxy in to the "glass"with a stiff brush. let cure for 24hrs, sanded smooth , and using automotive glazing putty to fill in any imperfections( blue stuff in pic). the repair is very solid probably the strongest part of the boat:D now i am sanding to remove most of the paint as it was badly damaged in the crash. hoped to get it painted by this coming weekend.
    ps here is some pics of a "small" rocket my friend Jason(pictured) and I are working on,this rocket will be fully finished in carbon fiber when done.(this is were i get my glass cloth from) the engine casing in the next pic is 29" long 54mm dia. the rocket is 7 ft 6 inches tall 6" dia. :D just thought I would explain the hi power rocketry comment in the above post:D
  4. #34
    May 2007
    co
    1,973
    almost complete! just waiting for my lettering, and some few minor touch ups, and it will be on the water this weekend!:D
  5. #35
    Ga
    5,267
    Wow, great repair job Jeepers!!!!! The rocket is pretty cool too.:D
    Doug
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
  6. #36
    May 2007
    co
    1,973
    Quote Originally Posted by D.Smock View Post
    Doug
    Thank you Mr Smock!
  7. #37
    3,117
    Jeepers,
    Is that a speedmaster rudder assy that your using? What strut did you use?
    Thanks,
    Mike
    Quote Originally Posted by Jeepers View Post
  8. #38
    May 2007
    co
    1,973
    Jeepers,
    Thanks,
    Mike
    Yep its speed master got it off this site! I am using an octura 3/16strut for .130 flex cable, but its set up for wire drive.
  9. #39
    May 2007
    co
    1,973
    Default Finished
    FINISHED cant wait to get it on the water:D :D
  10. #40
    PA
    505
    Excellent rebuild! I like the skeleton guy at the helm.
    Ken
  11. #41
    May 2007
    co
    1,973
    Quote Originally Posted by boater76 View Post
    Ken
    Thanks I cant take credit though it was my wifes idea for the "theme".
