Page 1 of 3 123 LastLast
Results 1 to 30 of 87
Thread: Project: Ugly Cat
    Mar 2011
    BC
    7,631
    Default Project: Ugly Cat
    Not quite sure what to call this at this time, I recently snatched this hull and hatch that he just happened to have around:
    I have one of these already but would like to do a different take on one.
    Mar 2011
    BC
    7,631
    I am going to use some spare accumulated parts here on this one. Twin(of course) TP 4050 950kv oldies, Etti 120HV's. Speedmaster hardware on the back. As I said I have one of these hulls already running so I have my targets all set and will run 10s2p.
    I am going with motors on the tunnel and therefore the struts centrally located and rudder between. As opposed to BlownAway which takes a very wide stance
    This hull has no rails so a custom HRC mount shall be in order. This hull should be substantially lighter than BlownAway as well.
    Jun 2012
    ny
    1,135
    Shawn, call it Genos cat I'll take it when your done. LOL
    Mar 2011
    BC
    7,631
    Quote Originally Posted by meangenesracing View Post
    I’m aiming for good runtime and a basher boat here pal. Something to run at that lake nearby with the waterski course on it. I keep building pretty boats and then fear the marker buoys.
    But you never know what else I come up with.
    Jul 2015
    701
    Nice pile of parts!!
    Jul 2016
    4,120
    Looks like a good start
    ON
    2,915
    Shawn
    I do hope that you are at least going to paint that hatch?
    A lower hatch may be in order.
    How big is that hull (10S-2P)?
    Larry
    AZ
    8,010
    The AC Boats R-42 is a great hull, especially for rough water. My 42” 10S version placed third among ~40 gas cats at the 2013 World's race in Houston. The hatch supplies a surprising amount of downforce, I would not change it out.
    Mar 2011
    BC
    7,631
    Shawn
    Larry
    I run 6s4p in BlownAway Larry. Granted generally 42-4400mah packs. And you wouldn’t believe the pull it has toward me painting it. And y’know I prolly will.
    Mar 2011
    BC
    7,631
    Jay, my friend took a shot at taking the hooking tendency out of the hull. He ground some of the leading edge of the runner in hopes that when the nose dropped in the corner that it wouldn’t carve inward. Just one side though for experiment sake
    AZ
    8,010
    That’s odd, mine didn't hook at all, neither in rough race water nor in tight turns. Haven't heard of this tendency from others either. All were single drives, perhaps twins exhibit hooking.
    Mar 2011
    BC
    7,631
    Yeah BlownAway exhibits none of the hooking either but I recall someone(Howard?) in that thread mentioning it. I think it was there, I’ll have to re- read it
    Mar 2011
    BC
    7,631
    I managed to get reinforcements done. I still need to clean them up but it is strong and still light.
    Jul 2015
    701
    Cool
    Mar 2011
    BC
    7,631
    Quote Originally Posted by Prodrvr View Post
    Cool
    Surprising how much that stiffened it up out front. The hull itself is plenty strong but the upper deck was able to flex some. This I discovered on BlownAway from the only blow over I had. The clear coat got spiderwebbed from the experience. OUCH!! And since I am not sure where this hulls service duty will stop(SAW?), an ounce of prevention....
  16. #16
    Jul 2015
    701
    Absolutely
  17. #17
    Jul 2015
    701
    What's your method for getting the interior hull shapes correct?
  18. #18
    Mar 2011
    BC
    7,631
    I use cardboard templates. I actually use Ram board which we put down during reno work. Then usually a little additional fit and trim for final install
  19. #19
    Jul 2015
    701
    Ok cool. I gotta try that...if I can get my hands to fit that far in the hull lol.
  20. #20
    Mar 2011
    BC
    7,631
    This is for the Cheetah? For that I would just do the deck to tunnel stringers:
    https://forums.offshoreelectrics.com...oof&highlight=
    https://forums.offshoreelectrics.com...at)&highlight=
  21. #21
    Jul 2015
    701
    No...I'm actually hating the Cheetah at the moment. I have buyer's remorse like you can't imagine. My concern is with the Central RC Marine 60" MTI I just bought. I ordered it with a full carbon interior...even the deck is done. I just want it to survive high speed crashes. My goal is to have it run high 80's.
  22. #22
    Jul 2015
    701
    Thank you for sharing those links for info!
  23. #23
    Mar 2011
    BC
    7,631
    I forgot about The CRC . Yes prolly just some bracing or combination of. The largest damage is from the deck collapsing and blowing out seams.
  24. #24
    Mar 2011
    BC
    7,631
    I got busy this morning and layed all this out and drilled it. Tinkered on the assembly through the day.
    I know it looks tight but it doesn’t take much rudder throw to get BlownAway to carve corners.
  25. #25
    Jun 2012
    ny
    1,135
    Shawn, what are you going to start with for strut depth?
  26. #26
    Mar 2011
    BC
    7,631
    I see you just got a 220.Same as BlownAway has been running. It has been awesome from day one. My goal on this one is longer runtimes and less amps in the corners due to the props being in middle.
    If you need that I can get depth to you in an hour or so when I get home.
  27. #27
    ON
    9,402
    Cool, inboard twin!
  28. #28
    Jun 2012
    ny
    1,135
    Yes I did get one and need one more and then I can try my twin R42 again I may need to raise my struts up some more
  29. #29
    Mar 2011
    BC
    7,631
    Gene I have Blown away set to 7/16” to prop shaft centreline. 1/4” from bottom of strut to table. Long round strut.
  30. #30
    Mar 2011
    BC
    7,631
    Well onward we go on steering. I used these ball links on BlownAway and they have been holding awesome. They are the old school Tamiya ones like off the Bruiser truck. A bit pricey but it does seem you get what you pay for. And it is advised to chase the threads on the left hand ones. Or the aluminum will fall and the turnbuckle will be pooched.
    It took a little bit of finicky filing to get the turnbuckles to slide nice and may take a bit more yet. Turnbuckles are from Secraft.
    This servo arm started as one of Kent’s(CustomCFParts) which I cut a new CF piece so my ball links are 49mm apart instead of 30. I have proper 3mm drill bits for holes.
    Next I’ll get the servo fixed.
