Page 3 of 3 FirstFirst 123
Results 61 to 87 of 87
Thread: Project: Ugly Cat
  1. #61
    Jul 2016
    4,131
    Wow, that was a fast turn around.
  2. #62
    Mar 2011
    BC
    7,633
    I happen to have some free time for now. I’ll see if I can get some Etti 120’s sent out quick unless anyone has experience with the YEP HV 120’s?
  3. #63
    Mar 2011
    BC
    7,633
    Quote Originally Posted by Peter A View Post
    That's a bummer Shawn. I understand how it feels after destroying a bit of stuff already this year, mostly due to not making sure I did what I knew I should do. Even still we take shortcuts and stuff things. Nothing like having to give yourself a kick for dumb stuff aye?
    I just beat myself up till I get it back and start the mending/improving. Then it’s back to a challenge. What amazes me though is electrolysis. Man it shows itself under water. That was just 30hrs.
  4. #64
    Mar 2011
    BC
    7,633
    So I got this fix for rudder rod boots figured. First a 5/16” end Mill on the drill press
    Then an old trick of putting a piece of brass tube inside the boot end before pulling it Thru the 5/16 hole. This is tricky but it works.
  5. #65
    Sep 2012
    Tg
    1,441
    Hi Shawn
    I have a YEP HV 180 and 120 esc's. It took me ages to figure out the programming as the program card has two levels of programs. You have to read through the program card instructions to learn this as it is not mentioned in the esc programming instructions.
    The only issue I have had with the 180 (I haven't used the 120 yet) is the start up speed. Because they are a watercooled plane/heli esc the start up is quite slow, even when programmed at max. It is ok in a mono, likely be alright in a cat, but no good for a hydro that needs a punch on the throttle to get it up out of the water. Otherwise they work ok and have a anti-spark built in which is quite good with HV.
    Did you consider the Seaking 130 HV esc?
  6. #66
    Mar 2011
    BC
    7,633
    Thanks for that Peter. So they are opposite of an Etti then. Which is hard to get a smooth takeoff with. Although on this last setup I set to slow start and it wasn’t too bad. I had heard good things about the YEP’s awhile back and read up on RCG last night before placing my order. $110 a piece helps take the sting out of the mishap. And I hadn’t seen the anti spark thing, that is cool. I think I had read these had the ‘active freewheeling’ too some time back, we shall see.
    BTW, batteries are coming along, two 4s packs charged and half of a 6. Not sure on the internal resistance now tho. But it’s worth a go.
  7. #67
    Mar 2011
    BC
    7,633
    Ok I got the YEP’s here and hey!!!, I can fit these where I originally wanted the ESC’s. I will put a couple standoffs down to hold the ESC’s up 1/4” off the tunnel floor. They will get a good waterproof job as well as per Peter’s advice. I need to wait for the programmer to arrive from China, ESC’s were in US but no programmer. Damn!
    Here is what I’ll be after:
  8. #68
    Mar 2011
    BC
    7,633
    Allright, so some water testing of foam and I’ve determined that this is plenty of foam to hold this boat up: I may add a chunk to the lid for that ‘just in case’ feeling
  9. #69
    Jul 2016
    4,131
    Foam is on my list of things to do for my current build. Any notion I had of just getting a few quick test passes in before doing so are out the window now!
  10. #70
    Mar 2011
    BC
    7,633
    No doubt, this one stung a bit. I had like 3 of my ‘I should have’ going thru my head!
    #1: I shouldn’t have run without foam
    #2: I shouldn’t have run after the flip
    #3: I should have just taken the kayak out to retrieve(that is the costly one).
    Oh well if it wasn’t for ‘the hard way’ I wouldn’t know half of what I do! Haha
  11. #71
    Jul 2016
    4,131
    So true
  12. #72
    Mar 2011
    BC
    7,633
    Well I did a few things with the ESC’s. Put barbs on the tubes and gave a few shots of urethane waterproofing. I also got the aluminum badge plate sunk in onto the fets. They kinda stuck the plate onto the tubes with heat conducting tape but it doesn’t touch the fets. Weird, so I remedied
    I glued down with heat transfer silicone
  13. #73
    Mar 2011
    BC
    7,633
    I also installed a bit of a cap bank
    And got my mounting ‘feet’ in for the ESC’s
    And installed everything. Good to go!!
  14. #74
    Mar 2011
    BC
    7,633
    So it went out on the water today, https://youtu.be/JBZuVVDELZY
    I feel it is a running a tad wet. A little cg adjustment is in order
  15. #75
    Jul 2016
    4,131
    It likes to turn, that's for sure. Good to see it back out and running
  16. #76
    Mar 2011
    BC
    7,633
    yes a different beast than the HPR for sure
  17. #77
    Mar 2011
    BC
    7,633
    Ryan, I should add that I set LVC to 3.4 on these ESC’s and they kicked off, I brought it in and when home packs were at 20% and 3.75.per cell, just mint!!.
  18. #78
    Sep 2012
    Tg
    1,441
    Hi Shawn
    Your start up seems real quick, much more so than I have been able to get. What setting did you use, if you can remember?
  19. #79
    Mar 2011
    BC
    7,633
    Hi Shawn
    Sorry to take a bit Peter but I wanted to check ESC’s to be certain. I went with ‘plane fast’ and 32%
  20. #80
    Sep 2012
    Tg
    1,441
    I think that is what I set mine at. Will have to check it when I set the esc up in a boat again shortly.
  21. #81
    Mar 2011
    BC
    7,633
    Well I tagged the throttle hard this morning and damn near put it on it’s lid. Should have had the camera on!
  22. #82
    Mar 2011
    BC
    7,633
    So I was playing with props a couple weeks back and ended up with a set of ABC1916’s on which were cut to 47mm. Not sure what speed I had a couple weeks back(55 I think) but today I had 61.8mph. That would be once it aired out and when I discovered the need for a longer rudder. I went thru this on BlownAway. The rudder is ‘tucked’ a little so I’ll try pulling it back and see if that will bring the nose down for the corner. Anyway here is today’s vid:
  23. #83
    Jul 2016
    4,131
    Nice. It's certainly running smoother, you can hear it.
  24. #84
    Mar 2011
    BC
    7,633
    Yes it is coming along, I thought that those props were 1916’s@47mm but as it turns out they are 1815’s. Mixed up the prop box somewhere. I put a set of full 1915’s on in search of a little more runtime and whoa!!! It ripped and got flighty. Motors were warmer for sure. Not really looking for SAW here so maybe back to 447’s. Next weekend for more testing.
    Also, once aired out it did not want to turn without a throttle blip so I relocated the rudder closer to transom. Totally helps but touchy as all get out. And I already had expo and travel tuned down.
  25. #85
    Mar 2011
    BC
    7,633
    And for the viewing pleasure https://youtu.be/QfeesV4yvps
  26. #86
    Dec 2013
    az
    1,228
    So 10s 2p per side??
  27. #87
    Mar 2011
    BC
    7,633
    Quote Originally Posted by rayzerdesigns View Post
    1p per side. And right now I’ve got Revo 435 gopacks @4400mah but charged to 4.20 they are really only holding 3700’ish mah.
