Results 1 to 19 of 19
Thread: Sea king 180 v3 ESC
    Feb 2018
    PA
    330
    Default Sea king 180 v3 ESC
    Hi all..... Are we finding it better to use an external BEC and batt on this esc...to avoid heat and LVC issues....say..on a 40/92. 1900 kv on 5 or 6s..... Already added another cooling line..... Or ....run as is....? Thanks...
    Jul 2015
    701
    I run a separate battery and add an 8800uF cap pack to it.
    Feb 2018
    PA
    330
    Quote Originally Posted by Prodrvr View Post
    In addition to the factory cap bank..?
    Jul 2015
    701
    Yes sir
    Jul 2015
    701
    But I run hot setups...6s 2200Kv.
    Feb 2018
    PA
    330
    And that's workin out good for you..? Nice... ..Thanks for the info..
    Jul 2015
    701
    So far, yes.
    Sep 2017
    409
    I put a EBEC on one of my SK 180 and have been running 4082 1600KV on 6s with no problems. Did that from the start after upgrading from the 120 I burnt up to the 180, why risk burning a expensive ESC when the EBEC's are cheap.
    Apr 2011
    tx
    1,284
    Been a while. To confirm, you just pull the red (pos) pin from the esc to receiver plug?
    Jul 2015
    701
    Just the red
    2,908
    Quote Originally Posted by stadiumyamaha View Post
    Yes. But I use a 3 in. servo extension. disconnect the red wire in the extension. Then you still have a good connection point when you want to program your ESC.
    I also do this in twin setups, I use two extensions connected together with the red wire disconnected at the radio end.
    Jul 2015
    701
    Not necessary on the SK180
    2,908
    How is it NOT necessary if you use a program box to program your ESC's and use a receiver battery or a U-BEC?
    Apr 2011
    tx
    1,284
    Good call. I used to do that but forgot about it.
    Jul 2015
    701
    The SK180 has a separate connection strictly for the program box. There's a wire from the box that plugs into the top edge of the esc.
    2,908
    Sorry
    Not all 180's are the V3 model.
    The three that I have are V1's - you must use the same three wire set that goes to the Radio Receiver for programming.
    Jul 2015
    701
    Didn't know V1's are still around lol, my bad.
    Jul 2015
    701
    However, the op is talking V3 here.
    Feb 2018
    PA
    330
    Yup..version 3..separate program port....Thanks for all the responses...gonna use an EBC...and a another cap bank...just to be safe....
