Hi guys i just bought a brand new dx5r from spectrum to replace my old futaba t3pk magnum and i am having a issue with it. I use a seaking 180 amp esc which the light canges from red to green when hull throttle is applied. My issue is that when I use the spectrum the colour does not change which means that it isnt going full speed even when the trigger is pulled all the way back. I have tried rebinding it but that has not solved the problem. Could you help me please.
Spectrum DX5R
Tags: None
Turn off esc, turn on transmitter, hold throttle at 100%, turn on esc whith throttle still at 100%, wait for two beeps, let go of throttle, wait for a few more beeps, power esc off, then back on again. Should be good to go assuming the problem isn't a trim or reverse setting issue.Vac-U-Tug Jr (13mph) -
Turn off esc, turn on transmitter, hold throttle at 100%, turn on esc whith throttle still at 100%, wait for two beeps, let go of throttle, wait for a few more beeps, power esc off, then back on again. Should be good to go assuming the problem isn't a trim or reverse setting issue.Comment
