Results 1 to 7 of 7
Thread: Motor wires being so small
    Aug 2015
    199
    Default Motor wires being so small
    Ok, Have aquired 2 Aquacraft motors 3656, 1800kv and 2030kv. Seams to me that the wiring coming out of the motors are small in dia. I use 6.5mm bullets (esc to motor). Both the 1800kv has little 2.5mm (maybe 3.0mm) attached. Just wondering if changing them to 6.5mm bullets (seams kinda small wires for the size bullet) will motor handle 6s? with a x645?? (maybe m445) Just wondering about the motor size wires heating up being so small.
    Oh, and a 150a ESC in a MC29v3, batteries would be 2s series to make 4s, 5000mah 50c each
    Hope I explained this well enough for you'all more knowledgeable than me to explain.
    John
    Feb 2018
    PA
    330
    Need a little more info....what hull......
    Aug 2015
    199
    Motley Crew 29v3
    Aug 2015
    199
    Motley Crew 29v3 Oh, the motor has been reinforced with 1/16 aluminum plate across the width
    Feb 2018
    PA
    330
    You really can't change the motor wires.....go to 5.5 or 6 mm bullets...and on that hull you should be fine....Start on a smaller prop...and work up ...if you can....watch the temps..on ESC ...motor..and batts....
    Ga
    5,266
    Quote Originally Posted by Johnc View Post
    John
    These are 4s motors. I don't think the rotors would last any length of time on 6s.
    You might find some of this interesting.. https://forums.offshoreelectrics.com...5-1500Kv/page2
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    Apr 2017
    QL
    1,038
    If you run on 4s and fit some 6mm bullets all should be fine. we run the low kv aquacraft motors in our limited class racing and nothing gets warm whatsoever.
