Results 1 to 14 of 14
Thread: Mono 33" Twin Setup, build advices
    FR
    2,096
    Question Mono 33" Twin Setup, build advices
    Hi,
    I' m building a 33" mono twin setup,
    Motors : 2960 , 2200kV , 1800 Watts maxi
    ESCs : 2 x Seaking 90A
    Batteries : 4S 3300mAh 60C - 120C Lipo per motor
    Any advice is welcome.
    Oct 2015
    313
    sounds really cool. Good luck with your build...….
    FR
    2,096
    Thanks, do you have an idea about diameter and pitch for the propellers ?
    7,629
    Geez, I guess you’ll have to go CNC to get CR props but I’d think 37mm could be a good size, maybe 35mm? I have a 40” twin mono running 442’s and it is running 50mph. TP 4030 1180kv on 8s 4200mah. I know it’s a different setup but it gives you an idea that you don’t need huge props to do well.
    FR
    2,096
    I was thinking about 38mm x 1,4 pitch for the props ...
    Aug 2014
    WA
    87
    I've built a couple of twin monos,there are pics on my page
    FR
    2,096
    Quote Originally Posted by RunningBeer View Post
    Thank you for sharing, cool boats !
    What is the setup of the Delta Force Pirate ?
    Aug 2014
    WA
    87
    It's currently 2x SSS 4082 2200 KV on 4S with 150 amp raider ESC's and 44mm 1.4 props. Cheers .R Beer. p.s. A generous hatch size is important when selecting a hull for a twin!
    FR
    2,096
    @ RunningBeer
    You build a "double" setup mono ! 4082 motors ... Is it a very fast boat ?
    Aug 2014
    WA
    87
    There's a bit of vid from an early run here https://www.youtube.com/watch?v=tobZ3H2icco . It's quick enough for my driving. The best part is how tight it can carve left and right turns.
    FR
    2,096
    I have 2 sets of motors :
    - 2 x 2960 2200kV , 175 Gr per motor
    - 2 x 3660 2400kV , 240 Gr per motor
    3660 motors are too heavy imho, what do tou think ?
    Aug 2014
    WA
    87
    The twin pursuit on my page had twin 3660's 2200KV on 4s. It's a similar size to what you are building.It was a weapon but I didn't reinforce the hull and she broke after several large crashes. I'm no expert but I think the 29's will struggle to dissipate the heat on a boat that big.
    FR
    2,096
    If I use 3660 2400 kV motors I' m afraid the boat will be heavy , + 130 Grammes.
    Dec 2009
    LO
    30
    Hello Alain !
    How are you ??
    Do you really intend to start such a project ??
    Do you know that you will have to use a drill and make holes in your hull ??
    You should do like the other boats you have, and leave it in peace on a beautiful shelf.
    cheers
