Results 1 to 6 of 6
Thread: Swordfish X+ 200A Current Limit Function
    May 2017
    OK
    1,460
    Default Swordfish X+ 200A Current Limit Function
    Looking for some info... Just put a new, SW X+200A W/Datalogging in my hydro. All is good, connect and program wise. It does have a Current Limit section with 4 options, Low, Med, High and Disabled. Does anybody have any info on what the current limit values are for these three options? I’ve looked all over the net, and SW’s Manual, as usual, really sucks, leaving out completely a description of this option broken down with more detail.
    These newer ESC’s have a Free Wheeling option. I highly recommend you use that. Good to see that option come to a boat ESC! It helps to significantly reduce the heat buildup of the ESC under partial throttle.
    Mar 2011
    BC
    7,331
    Free wheeling, nice. The YGE guys have that. As far as current limit, as I recall Hifei doesn’t state a lot of headroom. I think my 300 lites are rated for 350 burst. It would be nice if they would give a timeline for said burst, I have seen some advertise five seconds but no5 all
    May 2017
    OK
    1,460
    Yeah, guess I’m just going to have to experiment... If it works good, some current protection ain’t a bad idea!
    May 2017
    OK
    1,460
    Here’s this new ESC prepped and ready to go! I incorporate the ESC and Cap Bank onto the fiberglass ESC Mount plate. The bottom side shows the copper rails, made from 2 pieces of 0.063” copper plate, soldered together to make it 0.125” thick. Three caps is overkill for this 8s boat, but I was going to run it on 4s too, but gave that up. On 8s, the DF34 hydro is pulling 85A average and a bit over 100A digging off the corner. I back off about 10-20% just breaking into the corner and nail it at the apex. Works good on rougher water.
    Mar 2011
    BC
    7,331
    Looks great
    Jun 2015
    Ax
    73
    Check the KingKong III Pro esc...Has the same menu and explain more
    https://docs.wixstatic.com/ugd/6bc56...c9ed88e421.pdf
