Results 1 to 4 of 4
Thread: Neu 1527 Shaft to Coupler
    Apr 2018
    TX
    16
    Default Neu 1527 Shaft to Coupler
    Recommendations on best way to keep motor shaft from slipping inside the coupler? I have the neu 1527 8mm shaft and the big coupler with the 2 grub screws loctited down but after I hit a rough spot it slips now. Grub screws are black and worn down now. Shaft is scratched up.Why doesn't the motor shaft have a flat spot like the smaller motors..?
    ON
    2,913
    You have to file or grind flat spots on the shaft for the grub screws
    Larry
    Apr 2018
    TX
    16
    Dang I figured that but I also figured it would come RTR....I appreciate it man.
    May 2008
    TX
    1,744
    Quote Originally Posted by HYDRO333 View Post
    Doesn't hurt to tape up the front of the motor before you grind it to keep any metal filings out of the motor.
