And a few more
The motor mounts are 3/4" plywood cut to size ( trial and error ) and 5 minute epoxied to the hull and then painted in epoxy to waterproof. The engine mount is a piece of scrap aluminum I had lying around, bent and drilled to fit , took three tries to get everything right. All the water pickups and exits are stock and work fine
