Results 1 to 5 of 5
Thread: Heat sinks for ESCs
    Aug 2018
    MO
    21
    Default Heat sinks for ESCs
    I own a M41. Has anyone found and used heat sinks on the ESC. If so, what material and how did you attach it?
    May 2015
    139
    I would have to see a picture of the ESC to get an idea of how to attach. Aluminum is the material and you may need heat sink compound.
    SW26 V3 Green 35mph , Swifter Hydro 26. Delta Force 35. cars ,3 Rustlers 45-76 Mph.
    Aug 2018
    MO
    21
    yeah, I figured out a solution. A small fan on an aluminum bracket, a couple of screws and washers attached to the chassis directed at the ESC. Seems to work. Thanks Gearhead...
    Nov 2008
    Ql
    3,169
    Captain.
    I thought they were water cooled ESC's
    Aug 2018
    MO
    21
    They are, but the capacitors were getting hot. So the fan helps keep them cooler. The boat got too hot and stopped dead in the water one run, had to wait for it cool down. It hasn't happened since the fan install. Cheap fix...
