Results 1 to 3 of 3
Thread: wanting to build a 36 sprint cat with Twins
    Dec 2010
    3,119
    Default wanting to build a 36 sprint cat with Twins
    I have the HK 180 ESC,, I need suggestions for KV and size of motors I would like to run 4S on TP motor I'm thinking 4050 size at least thanks Chris
    2,913
    Chris
    I use a 36" Avenger hull, it is the same as the Sprit Cat on the bottom, it has more room and better access for twins.
    6S2P setup, HK 180 ESC's, TP-4050 - 1575 KV for oval racing - GPS 77 MPH on the straights.
    May 2018
    344
    I only have about 6 mos. of FE experience but a 4050 in my 40" Genesis did 86 so far on 6S. Wouldn't smaller 36mm motors be plenty in a twin 36" on 4S? Of course all I see are bigger and more powerful setups going into these meter hulls...
