Page 2 of 2 FirstFirst 12
Results 31 to 41 of 41
Thread: NEU MOTORS Vs SCORPION Vs TPPower
  1. #31
    Jul 2007
    642
    Quote Originally Posted by Speedfreek View Post
    Just do this Attachment 161640
    On the left standard and on the right my modified nipples lol
    Never noticed that issue on my Q-Mono cooler.
    Now that I realize it, I need to copy your modification.
    Thx, Ken
    Btw.....Surprised Terry Davis has not commented about the "Modified Nipples"....lol
    TenShock Brushless / Pro Marine
    NEU Motors / Rico Racing/ Castle Creations
    2023 NAMBA & 2018 IMPBA FE High Points "National Champion"
  2. #32
    Apr 2018
    OZ
    276
    Quote Originally Posted by Ken Haines View Post
    Thx, Ken
    All good, ideas from people in this forum is what this is all about, shearing ideas for our love of the hobby
    On My TP 5850 it has corkscrew fins by design, so the water coils so to speak from the inlet to the outlet.
    So with the bigger nipples in it now you would think it would help with more volume and flow .
  3. #33
    Aug 2010
    VA
    1,085
    Same here with Neu.
    I think HRC designed them that way maybe for specific flow??? I thought I was told this before, could be wrong.
    The smaller nipple bore at least on the outlet side will slow the flow a little and possibly increase thermal transfer of heat so I've been told. The key is the volume of water inside the jacket and as I posted earlier the stock TP jackets don't cut it in that regard.
    Futaba Team Driver
    - IMPBA Hydro Technical Director -
  4. #34
    Apr 2018
    OZ
    276
    Quote Originally Posted by don ferrette View Post
    Have you got a link to a jacket that works with the 5850 with fins ?
  5. #35
    Aug 2010
    VA
    1,085
    can't find a 5850 motor listed
    Futaba Team Driver
  6. #36
    Apr 2018
    OZ
    276
    I can't find one either
  7. #37
    Jan 2013
    Ga
    1,358
    The jackets you have say they are for the 56 series also so you might be able to get another brand 56mm one on. Its 58 because of the fins.
  8. #38
    Apr 2018
    OZ
    276
    Quote Originally Posted by jim82 View Post
    Specification:
    Model: LB56WCJ-50MM
    Applicable Motor Model: 56 Size Brushed/Brushless Motor
    Inner Diameter: 56mm
    Outer Diameter: 63mm
    Silica Ring Size: φ60X2mm
    Size of the Coppery Connector:φ5.0X9.5mm
    Weight: 45 gram
    Package Content:
    1X Brand New Leopard Water Cooling Jacket 56mm(DIA)-50mm(Length)
    Do you think this will work with a TP 5850 ?
  9. #39
    Mar 2017
    VI
    371
    https://youtu.be/_Y6mW7Klh_0
    This is an example of a leopard motor on 5s, 1800kv. An example of great result.
  10. #40
    Jan 2013
    Ga
    1,358
    Specification:
    Model: LB56WCJ-50MM
    Weight: 45 gram
    Package Content:
    I couldn't say for a fact being I don't have them in hand to try.
  11. #41
    9,402
    Back in 2014 I think?, I won 3rd in Q mono, Michigan cup with a 40" mono, SSS 5684-1200kv and SF240. ran cool as a cucumber on 4s2p. These are still available from you know where for about $115 all in.
