Results 1 to 9 of 9
Thread: Motor Rotation 1/10 Scale Hydro
    Jun 2017
    55
    Default Motor Rotation 1/10 Scale Hydro
    When I ran 1/8 Scale nitro we ran with left rotation when looking at prop from transom. Do 1/10 scale FE guys do the same thing?
    Thanks,
    Kevin
    Wa
    5,905
    They turn left and use right hand props
    Billy Graham
    Jun 2017
    55
    So I need a right lay flex cable?
    Sent from my VS985 4G using Tapatalk
    2,912
    Quote Originally Posted by klloyd67 View Post
    YES
    ca
    130
    Offshore Electric has both flex shafts and props needed for 1/10th scale.
    Jun 2017
    55
    Question?, if the brushless motors can rotate left or right and there are more prop options for left rotation, why wouldn't I run left hand?
    Wa
    5,905
    There used to be only a couple of RH props that would work but there are now quite a few to choose from. When the 1/10th scale first started in Seattle it was a bunch of Hydro Geeks that wanted to mimic the real Unlimited's and they turn left.
    Billy Graham
    2,912
    If you want to run with the 10th class and turn left. You want a right hand prop.
    If you run a left hand prop, you boat will not like it (very hard to turn left when spinning a left hand prop.
    The prop walk helps the boat turn.
    Jun 2017
    55
    Thanks, little slow on hydro physics
