Results 1 to 5 of 5
Thread: Swordfish 220 x won't connect to pc
    May 2007
    NY
    1,556
    Default Swordfish 220 x won't connect to pc
    It connected no problem and was programmed. I then checked out the data logging and it worked fine but then after the next run it refuses to connect again. I tried running as administrator and also deleting and reinstalling the software (6.0 or 6.1) without any luck. Anyone else have this happen to them?
    Sent from my SM-N950U using Tapatalk
    Team Liquid Dash
    Sep 2013
    IN
    848
    I've had the same, turned out to be a wire in the USB connector that was not connected to the board. Only found it because the plastic cover was so loose.
    May 2007
    NY
    1,556
    Well I will have to open it up and take a look, hopefully its that easy considering that is the only way to program the ESC.
    Team Liquid Dash
    May 2007
    NY
    1,556
    Didn't have to open it after all, purchased a new cable and it works like a charm again.
    Team Liquid Dash
    Sep 2013
    IN
    848
    Well that's good news
