Results 1 to 9 of 9
Thread: One or two ESCs
    May 2014
    VA
    3
    Default One or two ESCs
    Would like to run two identical motors on one ESC. Any problems?
    2,913
    This is what you would get.
    Jun 2018
    WI
    19
    One word maybe two SMOKE & Fire.....
    Apr 2018
    OZ
    276
    Lol
    Jul 2015
    701
    You definitely can get away with it on a low power setup, but I'm sure we're not talking low power here lol.
    Running two brushed motors on one ESC is no problem. Running two brushless motors on one ESC is problematic. The high-end ESC maker Schultze mentioned this in their ESC instructions, that it can be done by experienced bosters, but was not recommended. Like those above, my recommendation is not to do it.
    Jul 2015
    701
    Doesn't Flier make a few esc's that run two motors on one unit?
    2,913
    Quote Originally Posted by Prodrvr View Post
    Yes they do (two ESC's in one package $$$$), But if you have trouble with one, you have to replace both.
    I run two ESC's - it is a lot cheaper to replace just one if you have a problem.
    Sometimes when you have a motor problem it will effect or take out your ESC. so now you have to replace one motor and one ESC.(NOT TWO)
    May 2017
    OK
    1,464
    Agreed. Running two motors on one ESC can confuse the zero crossing detect circuits in the ESC, especially on corners. Even more problems under partial throttle...
