Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 91 to 120 of 226
Thread: PRO BOAT UL-19_How to run on 6S with stock prop
  1. #91
    Feb 2017
    na
    726
    Default Fastest UL-19 on YouTube @ 75mph
  2. #92
    Jul 2018
    WI
    1,013
    DELETED...
  3. #93
    Oct 2016
    pa
    476
    volantex vector pro ,proboat veles 29 , traxxas spartan, hobbyking/tfl pursuit ,ft009 with rescue rigging
  4. #94
    Jul 2018
    WI
    1,013
    DELETED...
  5. #95
    Oct 2016
    pa
    476
    Quote Originally Posted by sammyha View Post
    Oh man! That is a good one!!!
    oh you caught that before i changed it ...lol. yeah couldnt get a gif to load
  6. #96
    Jul 2018
    WI
    1,013
    DELETED...
  7. #97
    Feb 2017
    na
    726
    The second gps is about 10 years old and has a refresh scan rate of 1hz (reads 1 time per second) and it can't think as fast as the new technology the Dynamite has. The Dynamite scans on 10hz (reads 10 times per second). That's why I explained the gps data log in my video. I've seen that on several test if you don't hold the speed for more than a few seconds the old outdated garmins won't pick up the speed the boat "peaked at" if you just hit the speed for a split second. Below is a member on here's test of the two gps devices. Clearly the new technology is faster...
    https://www.youtube.com/watch?v=SZfRoMprTro
  8. #98
    Jul 2018
    WI
    1,013
    DELETED...
  9. #99
    Jul 2018
    WI
    1,013
    DELETED...
  10. #100
    Jul 2018
    WI
    1,013
    DELETED...
  11. #101
    Jul 2018
    WI
    1,013
    DELETED...
  12. #102
    Jul 2018
    WI
    1,013
    DELETED...
  13. #103
    May 2017
    OK
    1,464
    Guys, this is becoming a cat fight... let’s just drop the rhetoric and get along. You guys both have fast boats and unless you bring them to a SAW event and get them officially timed, you could go back and forth forever!
    All GPS units don’t have sub MPH accuracy or repeatability you both are claiming so just go and have fun. I’m sure if you guys got together, you’d just pull some beer tabs together and have a good laugh. But I think the rest of us are getting a little tired of coming on the site and seeing these posts. I ask that you guys raise the bar in the conversation.
    I’m wondering about the absence of any moderators....
  14. #104
    359
    It seems the Moderators only get involved when you violate the rules in the "For Sale section" ……………...
  15. #105
    Jul 2018
    WI
    1,013
  16. #106
    Jul 2018
    WI
    1,013
  17. #107
    Jul 2018
    WI
    1,013
  18. #108
    Jul 2018
    WI
    1,013
  19. #109
    Jul 2018
    WI
    1,013
  20. #110
    Jul 2018
    WI
    1,013
  21. #111
    Jul 2018
    WI
    1,013
  22. #112
    May 2017
    OK
    1,464
    Very nice machining and fitting! This is a big part of the sport, and where you really make a connection to your boat. Please keep posting your upgrades!
  23. #113
    Jul 2018
    WI
    1,013
  24. #114
    Jul 2018
    WI
    1,013
  25. #115
    Aug 2010
    uk
    2,887
    Make sure that the Aeromarine coupling releases on the flex when you undo the coupling, these type of couplings with the separate brass piece can tend to be a bit of a pig either getting the brass collet to release from both the coupling taper & the flex.
  26. #116
    Jul 2018
    WI
    1,013
  27. #117
    Jul 2018
    WI
    1,013
  28. #118
    Aug 2010
    uk
    2,887
    A lot of the Chinese couplings of this design can be a problem getting the brass collet to release from the flex even after getting them to release from the taper, you can also use some anti seize paste on the outer taper & thread parts to get the coupling nice & tight without putting to much pressure on the wrenches, this stops galling of the stainless. only put this on the outer tapers & threads & not on the flex, a number on the forum use anti seize on their coupling threads to good effect.
  29. #119
    Jul 2018
    WI
    1,013
  30. #120
    Aug 2018
    57
    This whole thread is amazing. Well done
