Page 7 of 8 FirstFirst ... 5678 LastLast
Results 181 to 210 of 226
Thread: PRO BOAT UL-19_How to run on 6S with stock prop
  1. #181
    Jul 2018
    WI
    1,013
  2. #182
    Jul 2018
    WI
    1,013
  3. #183
    Jul 2018
    WI
    1,013
  4. #184
    Jul 2018
    WI
    1,013
  5. #185
    Jul 2018
    WI
    1,013
  6. #186
    Dec 2010
    NY
    3,120
    Quote Originally Posted by sammyha View Post
    This looks like as clean of a setup as it gets to me.
    Same result as with the enlarged cooling slots...
    put your water pick up threw the front right sponson just drill the tubing threw on a angle that's no good,,what you have ,dragging,,,,,,,,,,,,,,, unless you want to do a prop wash pick up
  7. #187
    Jul 2018
    WI
    1,013
  8. #188
    Aug 2018
    AZ
    57
    Like this...
  9. #189
    Jul 2018
    WI
    1,013
  10. #190
    Aug 2018
    AZ
    57
    Very good, well done! Running it soon?
    Not quite yet. I have been traveling for work so i decided to let some guys at the local hoppyshop do some of the wiring work while I'm gone. Shortening the wires between the motor and ESC and all connectors will be Castle 6.5mm bullets...including all the batteries. Should be ready when i get back in a week for me to switch out the servo, install the cooling lines, add an after-market turn fin and then, of course, the strut height/pitch adjustment which, frankly, seems to be the most complex of anything to me.
  11. #191
    Aug 2018
    AZ
    57
    Sam,
    Fortunately, with all the time I had waiting for the boat, I did manage to build a nice custom carrying case for it as well as a retrieval rig which i am hoping will be large and powerful enough...IMG_9424.JPGIMG_9426.JPGIMG_9476.JPG
  12. #192
    Jul 2018
    WI
    1,013
  13. #193
    Aug 2018
    AZ
    57
    Oh WOW! Very nice! Are you putting floatation foam around the pipe on the rescue boat?
    Oh, yeah, absolutely. Cutting the noodles as we speak!
  14. #194
    Jul 2018
    WI
    1,013
  15. #195
    Jul 2018
    WI
    1,013
  16. #196
    Jul 2018
    WI
    1,013
  17. #197
    Jul 2018
    WI
    1,013
  18. #198
    Aug 2018
    AZ
    57
    Interesting post. This is the exact situation I want to avoid because I've been close with one of my cars and realized I was spending more time tinkering and upgrading than I was actually just having fun driving it around. Of course, I'm not looking to hit 70+mph speeds but rather be able to run it around at 60+ with good control and at least a few minutes of battery life. I do salute the work and experimentation you've done however as, at least speaking for myself, you've allowed me to avoid a great deal of trial and effort and I've learned a ton from reading these posts. Much appreciated!
  19. #199
    Oct 2016
    pa
    476
    Then I applied a thin layer of E6000...
    Next time I knock one off, it will be floating in the area of the wreck...
    nice work .
  20. #200
    Mar 2014
    IA
    165
    I would say the dual water is the problem, They extend to far down and what I would do is cut some off the pickup pipes off and bend forward close to 90 degrees and leave the pipes inline. The current long pipes cause drag. BTW, nice BOAT.
  21. #201
    Jul 2018
    WI
    1,013
  22. #202
    Jul 2018
    WI
    1,013
  23. #203
    Jul 2018
    WI
    1,013
  24. #204
    Jul 2018
    WI
    1,013
  25. #205
    Jul 2018
    WI
    1,013
  26. #206
    Mar 2011
    BC
    7,631
    Sounds like a bit of a ‘Ah hah’ moment. We all have them. Can’t see the forest thru the trees, blah blah.
    I have limited hydro experience but one thing I have had success with is pulling water off the sponson bottoms. IF you are having cooling issues. This should be less for you as the water cools now. I love fall/spring running for this reason.
    Also if you are going back to stock on the rudder you can take a debuting ball(Dremal) and just teardrop the inlet of the rudder. This is usually plenty.
  27. #207
    Jul 2018
    WI
    1,013
  28. #208
    Jul 2018
    WI
    1,013
  29. #209
    Aug 2018
    AZ
    57
    Do you know how thick that piece of wood is? Meaning, my local hobby shop has tons of variable thickness wood sheets and it would be great to be able to just go but the exact pieces I need. Sorry, may be a few questions coming in- I'm now in the heat of setting my boat up :-)
    My hydro setup on the countertop.
    The wood under the sponsons is the same thickness as the measurement from the bottom of the strut to the prop shaft centerline.
    Study that statement carefully...
    This means the bottom of the sponsons and the prop centerline are on the same plane.
    I recommend to zoom in on this photo too.
  30. #210
    Jul 2018
    WI
    1,013
