Results 1 to 7 of 7
Thread: Delta Force Mini Sniper Build
    Jul 2017
    VI
    94
    Default Delta Force Mini Sniper Build
    Im planning to build a delta force mini sniper as a 2s or 3s boat. Its not for me but for someone else and I'm trying to keep the prices low while at least being able to get the boat into the 30 - 40mph speeds. Does anyone know of any setups that are capable of doing so for under $450?
    Jul 2017
    VI
    94
    Also what do you guys think about using the Mini outboard motor system that is available on OSE for $74 along with the OSE raider 150A esc on 3s for this boat?
    9,402
    Hell ya! I love the Leopard 2860- 2550kv motor, a 120amp esc and 3 or 4s. Run up to a x435x3 blade detongued.
    9,402
    150 esc is too big. An old Hobbywing 120 v2 still available from Ali express or Banggood.
    Jul 2017
    VI
    94
    Thanks! Also which size flex cable would you recomend?
    9,402
    I think .130 cable is fine. It's what I've used and works fine. We are only pushing a 23" hull.
    Do a search for DF23 and you will see some builds to help you out.
    9,402
    A bit over kill but you know what this hull maxed out can take size wise for components. Thanks Tony!
    https://forums.offshoreelectrics.com...highlight=DF23
