To make each motor see both 8S packs, you need to connect the two red input wires on the ESC together, and the two black input wires on the ESC together.
This will stop one side from pulling the battery down more then the other.
You also need to move your motor coolers, so that the output is at the top of the motor.
If you cannot rotate them because of the input hitting the hull, you need to drill and tap a new output hole in each cooler at the highest point of the cooler,
then put a set screw with some sealant on it in the old holes.
6 min. is a long run time, your packs should never be below 20% after a run.
