Results 1 to 9 of 9
Thread: SAW Sponsons
    Mar 2015
    sa
    39
    Default SAW Sponsons
    Hi.I am after a set of SAW sponsons for a 6s rigger.Thanks
    Sep 2007
    2,783
    Don’t be surprised if no one answers. SAW sponsons are part of the secret recipe racers are unlikely to share. I suggest you start with a JAE sponson and then test and modify. Try different widths and angles of attack till you are satisfied.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    Mar 2015
    sa
    39
    Thank you for your input.Its funny you say JAE sponsons as i have tried them with sucsess.They fell apart on the last run i had.Maybe i should be asking if someone has a SAW rigger for sale
    Sep 2007
    2,783
    Once you get to a certain speed SAW rigger sponsons and their booms become expendable items. I build 6 pairs of sponsons for new SAW boats these days as any crash it almost a guarantee a sponson and/or boom will break.
    I came up with a good system where I would design the sponson as a 2D profile similar to a JAE with my own angles. I would buy a 12"x48" sheet of foam and birch ply and make a large sandwhich panel. I would laser cut an acrylic router template and using T-pins to hold the template on the sandwhich panel using a trim bit I would cut as many sponsons as I could from a single sheet. The router template also had plunge holes where the boom tubes would go making it easy to have consistent boom placement. I would then glue on ride pads and bond in tubes for the boom.
    Later versions used a center rib in the sponson and laser cut wood frames. The routing was necessary to trim the foam to the sponsons. Notice how I also hollowed out the sponsons to keep them light.
    Tyler Garrard
    Mar 2015
    sa
    39
    Wow.That is awsome.I have a pair of JAE i am working on now.Looks like you have a pair of sponsons for me. hehe or would you be willing to make me some working with mine and your design.Thanks
    Sep 2007
    2,783
    Sorry I only build SAW components for teammates.
    Tyler Garrard
    2,727
    Randy Naylor at BBY Racing may be your man, I know he has built SAW boats for profit in the past.
    6,190
    Tyler, I would never ask you to tell us all your secrets but is there an AOA range that's sensible for a sprint boat and an AOA range that's sensible for a SAW boat? haha And never the tween shall meet?
    Noisy person
    Sep 2007
    2,783
    Terry, they tend to be different and the width of the ride pad changes too.
    Tyler Garrard
