Page 1 of 2 12 LastLast
Results 1 to 30 of 51
Thread: JAE33FE Build
    Apr 2011
    102
    Default JAE33FE Build
    Here is my JAE33FE that I am close to completing. It will have TP 4082 2310KV, and Swordfish 220A esc, the rest is the complete combo from Zippkitts.
    The beginning, doesn't look like an RC Boat..
    Taped it together to check out the size.
    Lowered the battery height for more room, need to clean up a bit.
    Inner Frames, Sides and Bottom glued.
    Motor Arrived
    Apr 2011
    102
    Size compared to the 12G4
    First time using a Swordfish ESC
    Second of 3 Coats of Finishing Resin
    Ready to Glue on top plate, hatch fitted and trimmed.
    Thumbscrews added to hold hatch, hate them falling off in transport!
    Apr 2011
    102
    Ski on and glued to hull.
    Top plate being glued
    Sponson sheeting almost done
    Sanded and design taped for paint
    AutoAir Silver Sealer (Primer). Great paint to work with..
    Apr 2011
    102
    Racing Green Candy over silver sealer and silver metallic base coat.
    Nice and even application for candy paints, Harbor Freight gun works nice!
    Tape removed and areas that will be black exposed.
    3 Coats of Transparent Black
    Ready for 2k Clear Coat
    Apr 2011
    102
    2 coats of clear, you can see the candy coming out of the hatch. Need to wet sand and final clear coat.
    3rd clear coat going on in home-made paint booth
    Hardware going on, nice attention to detail with all the fittings from Zipp.
    Motor in, the pile of parts in back waiting to go in. This is current status, should be done end of week.
    Sep 2017
    409
    Looks awesome!! I really want to build one of these for my next boat.
    Apr 2011
    102
    Thank you, they are really nice to build. Received the batteries today, need enough power for the TP motor, so I went with Gens Ace - 5800mah - 100c packs.
    Ga
    5,266
    Nice work!!
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    Apr 2011
    102
    Nice work!!
    Thank you!
    Apr 2017
    QL
    1,038
    Let us know how she runs with the T.P. 2320.
    Apr 2011
    102
    Quote Originally Posted by rol243 View Post
    Will do, had a small typo its the 2310kv.
    Made some progress, hope to maiden tonight. The only thing I would like included in the kit that is missing, is a stand. Would be nice to have a stand that is laser cut with Zipp logo. Not that they are hard to make, would be a nice option.
    All Electronics in
    Just have to sharpen fin, and attach sponsons
    Turn-Fin sharpened and attached.
    Might need to paint brass thumbscrews black, pretty much ready for maiden. What would you guys suggest for props to test? I put on an X442 to start and get setup right, then might try the provided 1450, or ABC H7.
    Apr 2011
    102
    Here's an action shot of the blue Jae..
    Apr 2011
    102
    Ready for maiden this afternoon:
    Apr 2017
    QL
    1,038
    good props; ABC H6 / H7 / zippkits 1450 mod.
    Jan 2013
    Ga
    1,358
    Abc 1914 or 1915-17-45
    Jan 2013
    Ga
    1,358
    Quote Originally Posted by M3Bluegsr View Post
    I have a 12 I just built and went with electric right now it has a leopard 2860 5050kv 2s 56mph with abc 1514-17-45. I have a Tp 2940 2800kv im going to be trying on 4s.
    Im working on another 12 right now im going to be putting a Tp 2940 3770kv in it on 3s.
    Apr 2017
    QL
    1,038
    Jim, not sure if the JAE would like the 19 series lifting prop due to the Ski which does the lift. we are now trying to reduce lift by Tip Cupping the props for more blade in the water.
    Jan 2013
    Ga
    1,358
    My 33 likes the 17-45% props. I haven't taken it to the pond lately but I have a 2117-19-38% im wanting try with the 4060 1950kv motor that is in it now
    Apr 2011
    102
    On the right track with props then, noticed others used those and wanted to confirm.
    Apr 2011
    102
    Maiden went well, no mechanical issues during run! It definitely wanted a larger prop than a X442. I also had a decent amount of drag from turn-fin, so I will re-work and sharpen some more.
    Apr 2011
    102
    Quote Originally Posted by jim82 View Post
    Very nice, did you modify a lot, or make things fit within the existing nitro design? The motor could probably go where fuel tank is, but any issues with battery placement and interference with boom tubes?
    Jan 2013
    Ga
    1,358
    Apr 2011
    102
    My only small critique was that the kit did not have a stand, huge thanks to Zipp for the laser cut one! Great service! (I did modify slightly to show off paint job.)
    Did some testing at my subdivision pond. So far I think the H7 prop performed the best.
    Loving the Hydros
    In the water, I'll try to get a video next week.
    Jan 2013
    Ga
    1,358
    Try a 1915-17-45
    Apr 2011
    102
    I'll have to order that one, I had 1450 from the kit, was looking for an H7 during the build and picked one up when OSE got an ABC shipment not long ago.
    Dec 2013
    138
    I am starting two of them. Lots of boats but first riggers. Using 4082 1600Kv on 6 cell. Should be about same prop rpm as yours. Did you decide on which prop you like? Any other tips now that you have it running? Thanks, Bret
    Apr 2011
    102
    Quote Originally Posted by SlickZERO View Post
    I haven't tried the 1915 yet, but I like running the H7. I had to upgrade from the EC5 connectors because on 4S my amp draw was heating them up, might not be an issue for you on 6s or if you already have good connectors.
    Other tips:
    1. Lower battery tray height as much as possible, either cut out some of bracket or thin out main tray piece. Even though mine are already lowered, its a tight fit with the packs strapped in. I'm waiting on Mojo 4s 6K mah battery packs to see if I can get them to lay horizontal vs on edge in my pictures. I can fit up to Gens Ace packs with 47mm width (25mm height) on their edge (too tall to run flat = 25mm x 2 = 50mm). The Mojos are 48mm width (will be really tight /not fit on edge) and 18mm height, if I lay them flat, 18mm x 2 packs = 36mm. 36mm is below the 47mm battery height I currently run and already know boat can handle more than 50mm wide packs. Mojos packs might be a good solution to my battery height.
    2. Come up with a way to mechanically secure the hatches. I added thumbscrews to this Jae, but on my nitro I didn't. Having the hatches fall off in transport is unavoidable at times, don't want them getting broken / scratched from falling off especially if you took the time to paint.
    Other than that, nothing really. Boat runs great as expected.
    Dec 2013
    138
    Thanks for the information!!!! If I figure this right you run about 6000 mah total with 2 - 2 cell in series? For same run time on 6 cell I would need 4000 mah (2/3 the amp draw) So 2 - 6 cell 2000 mah in parallel would be the same. I like parallel set ups because each battery/connector only "sees" 1/2 the amp load.
    Apr 2011
    102
    Welcome! What size packs is kinda up to the user goals as long as you meet system / space requirements. Don't know if you're racing or bashing, but doing the math can give you an idea of where you'll end up. I have 5k to 6k mah packs in use, I haven't timed a run and then checked mah used. If I had to guess on 4s with 5000mah I am getting around 3 minute run time with the setup leaving the 20% pack mah overhead requirement.
    Not as critical on 6s but don't forget pack capacity and C rating can be a limit as well, Ah X C rating = pack amp rating. 5000mah is 5Ah and a good battery pack's true c rating is probably around 30C, 5Ah x 30C = 150 amps potential.
    Apr 2011
    102
    Just re-read your quote and wanted to clarify. You would need one lipo 6S 4000mah, two 6s 2000mah packs in parallel, or 2 3S - 4000mah packs in series. Series doubles voltage but keeps capacity the same, where parallel doubles capacity and keeps voltage the same.
