Results 1 to 7 of 7
Thread: Lipo balancing ?
    Jan 2011
    497
    Default Lipo balancing ?
    Hi all im using an Astro flight Blinky balancer to re-balance my 4S 5000 mah lipo's. The cell voltages vary between 4.19 v and 4.21v per pack. I realize that all for 4 cells should read the same voltage. What would be an acceptable voltage difference in a 4S pack ? Regards Andris Golts.
    Apr 2017
    QL
    1,038
    those readings are ok. i doubt that you would get any pack to balance out to 4.2 volts per cell exactly. you might get a closer reading if you tried a different balancer / charger.
    Aug 2010
    uk
    2,887
    Yep i think within .02 volts per cell is good.
    9,400
    What charger?
    Jan 2011
    497
    Hi Ray i have i use Hyperion EOSO6O6i and EOSO61Oi chargers. Regards Andris.
    9,400
    Good chargers. There is a way to charge one cell at a time to bring it closer to the others. Larry and I are are pretty AR about balance and try to balance to the 3rd digit if possible.
    Larry uses Hyperion balancers and recently I have gone to ISDT. I also love the ISDT q6 Plus chargers. Got great deals on them last fall.
    Apr 2011
    5,666
    Yup.
