Wire drives for bigger set ups.
Hi All
I have a question, for those with the knowledge regarding wire drives on bigger boats.
I am planning for my next build, the hull is a 46" mono which I will be using for endurance racing so the power will not be huge. I am looking at using a TP 5660 or 5680 motor of 450-520 kv on 10s. The current draw has to be 50 amps or less for 20 min, so the props will be a little smaller than gas, probably Prather 250-260 or similar.
My thinking is to mount the motor forward in the hull to give me a better ability to adjust CG with the batteries as the hull has 5" rails in it already and putting the motor right at the back will mean a very short 1/4" flex, which is doable anyway and probably easier, but...
What size wire drive, 1/8"? How much power would it take? Could it also run a 5680 size motor if I wanted to? The wire shaft etc I can make up, but where would I get an 8mm-1/8" coupling. The length of the wire would be 15-18" in length I think, I will have to measure the hull and check.
Behind these thoughts is one of reducing driveline friction, therefore reducing wasted amps.
What say any of ye?
