Results 1 to 8 of 8
Thread: Old Shovel issues
    Mar 2011
    BC
    7,629
    Default Old Shovel issues
    To the scale guys, what dang prop do you run on these?
    I have been working my way thru my smaller props on this boat https://forums.offshoreelectrics.com...=Miss+Cadillac
    Last prop was a cut up 440(37mm) with a bunch of mod work.
    It was good till about 2/3-3/4 throttle then it tosses the back end up.
    Next and last prop I have is a 438 cut to 35mm and detounged.
    I am not expecting a go fast boat as we are trying to run at the city park.
    Thanks, Shawn
    Wa
    5,905
    Well with the proboat 1500kv motor a X447 work well I have never run the motor you have but I am thinking maybe a 42 or 45? I looked at your other thread can you tell me how deep the sponsons are and how deep your prop is? Also what does this boat weigh RTR?
    Billy Graham
    Mar 2011
    BC
    7,629
    Thanks Jim, I’ll check on this when home in an hour or so.
    It is light, at least by my standards
    Mar 2011
    BC
    7,629
    Quote Originally Posted by JimClark View Post
    The sponsons are 1 1/4” deep as is the hub of the prop. Well more like 1 1/4” at rear of of hub.
    RTR weight is 97 oz with a 4200mah 4s pack.
    Pretty sure it is an 1800kv motor
    AZ
    8,010
    I’m confused, a UL-1 motor is 2030 Kv not 1800. If the transom is hopping then either the prop has too much lift/down angle/too deep or the CG is too far forward. A Kv of 1800 would work better with an x445.
    Beautiful boat BTW.
    Mar 2011
    BC
    7,629
    And it is a gold can AQ motor of 1800 Kv
    I know these aren’t supposed to be fast
    Damn phone pics, haha. I have RTR CG 2 1/2” behind sponson trail edge.
    Wa
    5,905
    CG should be closer to 1 inch behind the sponson's. Those sponsons are a little deep my boats have been more like 1 inch deep and the center of the drive dog also at 1 inch.
    Billy Graham
    Mar 2011
    BC
    7,629
    Now that I measured the CG I would’ve thought it was a lot closer to the sponson edgebased on the behaviour
