Page 1 of 2 12 LastLast
Results 1 to 30 of 41
Thread: The new guy...
    Jun 2018
    ny
    218
    Default The new guy...
    Just figured i would say hi...LOL joined up for more info on a boat i just got, an old Graupner Monster vee. Boat came with a resistor speedo powering 2 graupner speed 600 motors, thru a 2:1 gearbox, out the back thru a strudder with a carbon Graupner 47.5mm prop with 1.2 pitch.... so far i swapped out the speed 600s for a 2150kv bruahless system, and plan on running on 3s...
    i had rewired the speedo to power just 1 of the motors since it was slow as snot with them powered in series (and i knew it wouldnt have an icecubes chance in hell of running both motors parralel on 3s) and the few min it ran, porpoised like mad... but ran nice and fast...LOL for a wiper speedo brushed sealed can motor....
    Anyone with tips on the porpoising?
    There are several common reasons for propoising:
    - the hull design limits the speed, too fast and it runs poorly
    - the CG is too far back
    - strut is angled up at the prop end
    - prop is running too deep or too shallow
    Jun 2018
    ny
    218
    I doubt that its the hull design, as it was billed as the fastest stock electric of its time when it came out, designed to run 14s nicads, and when i get it up full throttle even in stock form with 3s lipos, it will porpoise... i have tried strut up, strut level, strut down, all to no avail...cant really adjust prop depth, and i have tried shoving extra weight (an extra 3s lipo pack in the battery tray and even stuffed up further than the tray.)up in the nose of the hull, which hasnt really done a whole lot either...
    Jun 2018
    ny
    218
    Please forgive the messy bench....LOL lots of projects and hobbies here...LOL but heres a pic of what we are working with...
    And a short vid of it running the stock driveline, twin speed 600s in series, on 3s (11v on a setup originally designed for 14-16v)
    2,728
    S14 was a restricted class and not as fast as Mono2 was at the time despite the extra 2 cells. I Don't know the boat as I was on a break from racing when it was out, but it may well have been designed with some rocker from the factory to get the nose up on the limited power they came with. Put the hull on a flat surface and if it curves upwards at the stern, that is rocker, and making it go faster than its design speed will always result in porposing.
    You could try fairing it flat with filler, or what we did to race RTRs with rocker is cut off the transom just before the rocker starts, cut the now separate transom off about 5mm forward of the transom, turn the transom around and glue it inside the new back of the hull, creating shorter hull with a new transom with a sharp 180 degree edge and no rocker.
    Jun 2018
    ny
    218
    If i am understanding you correctly, there isnt a rocker to it, bit it does look a little deformed under the r of monster vee, would that be causing the porpoising?
    Also, i havent run it on the new brushless setup yet, but current cg seems pretty good, at 9 1/4" forward of the transom on a 28 1/2" hull...
    Jun 2018
    ny
    218
    Might as well add a pic of the box, and how the boat is currently laid out....
    Jun 2018
    ny
    218
    And....LOL heres another graupner hull thats seemingly identical doing exactly what i want mine to do...LOL i wonder if i just need trim tabs or something? Seems all the fast graupner vees have them....
    Mar 2014
    IA
    165
    Needs info and more reading on his part to help him out. I'll help him.
    Mar 2014
    IA
    165
    Post info not needed as suggestion, thanks!!
    Jun 2018
    ny
    218
    Got to run it on the brushless, as set up in previous pics, not too bad, definately more peppy, also much smoother with the improvised trim tabs (soon to be replaced by real adjustables, as soon as they show up...LOL as for gutting the boat, maybe in the future, i am pretty happy with it for now. If i am buying hardware for a boat its gonna be for building a gasser, in the 48" range....i have an abundace of professional grade stihl brush cutter engines (perk of being a certified tech) that i would love to convert to rc boat use... couple of 27cc, a 32cc, and a 36cc 4 stroke.... one of those should work well....LOL not looking to break any records, just a larger fun boat that runs for a bit longer.... probably either gonna get a fiberglass hull and fit it out or a zippkits hull.... one or the other.... few tempting fiberglass hulls on ebay....
    Anyways heres the vid on 3s with the new brushless....
    Mar 2014
    IA
    165
    Now from what I gather your happy with it.
    Jun 2018
    ny
    218
    Quote Originally Posted by Norwest View Post
    Now from what I gather your happy with it. I'll remove my post!
    Not a problem Norwest!!! Someday i will gut it for a straight driven setup... for now its plenty fun...LOL actually sitting in the car at the edge of the erie canal in upstate ny waiting out rain to run my second pack thru the boat tonight... :-)
    Jun 2018
    ny
    218
    So...LOL i cant leave things well enough alone.... found a prop shaft that was the right size to convert my 4mm setup to take 3/16 props.... good old Octura mad the shaft, 4mm and the prop end steps up to 3/16 with a drive dog.... so i picked up a few plastic props to play with.... found that this boat really likes a 52 mm 1.4p 3 blade.... motor is about 140-150° after 2 back to back packs on 3s... and its about 5mph (according to the eyeball) faster than the 47mm 1.2 that was on it when i got it.... now i may just have to invest in a metal prop...LOL
    current back end with the trim tabs i got and new prop...i may have to flip the trim tab adjusters over to make them hold better, or go longer screws... one of the 2....LOL but it planes out nice right now....
    Mar 2014
    IA
    165
    delete
    Jun 2018
    ny
    218
    Norwest, thanks for the tips! As for the trim tabs, they are spaced about 1/16 up off the back edge of the transom. As for prop angle, i would say prop is currently down a degree or 2. As for prop, keep in mind this motor/prop combo is running thru a 1.5:1 gear box still...and can i say it gets on plane with that 3 blade like a bobber popping out of the water...LOL and the temps stated were after about 15 min of runtime, with no water jacket.... the jacket is on the short list of items i need to get...LOL i never had any issues running my rc car brushless these temps either... esc after that 15 min is barely even warm.
    I will get a vid of how well it runs sometime soon....LOL next time i am out with it...
    Mar 2014
    IA
    165
    You have it well in hand! I'll be reading and won't post!
    Jun 2018
    ny
    218
    question for you norwest (or anyone who cares to answer for that matter), on the props, i have read a lot of different ideas on diameter vs pitch....according to the calc here, it looks like the 39mm 1.6 prop you mentioned would push to roughly 33mph, factoring 80% efficiency, and 25% slip... would that prop actually have less load on the motor, considering the 52mm 1.4p prop is good for (again, theoretically, according to the calc) 26mph? also, wouldnt (due to the 1.5:1 gearbox) a smaller prop be more prone to cavitate due to increased torque, or am i nuts on that one? oh yeah...boat is not all that light either... need to weigh it at some point... im sure that has an effect on load and prop size....
    i dont really know the effect on the loads in play here (im a lowly john deere mechanic, not a fluid dynamics scientist...LOL)
    also, is there any operational differences between a silicone water jacket and an aluminium one, or is it just for looks?
    all i can do is ask...LOL there are many here (probably all here...) who know more about FE boating than i do... im here to learn!!!
    Jun 2018
    ny
    218
    And as promised... some vids....
    Mar 2014
    IA
    165
    max speed for that boat. Your work has paid off!
    Jun 2018
    ny
    218
    I guess its not too shabby for a $150 investment, all parts included...LOL would a set of turn fins be worthwile to prevent the spin?
    Mar 2014
    IA
    165
    Yes it would.
    Jun 2018
    ny
    218
    So.... few big things in store... hoping to test them out tomorrow.... switching to full watercooling, upgrading the underpowered 80a air cooled esc to a 150a flycolor, and added a silicone waterjacket to the motor... now i have the ability to run 6s as well... hehe run 2 3s packs in series... also got the turn fins a few weeks ago but havent been able to get out to the canal yet...
    Mar 2014
    IA
    165
    I see a lot of trouble abound with cooling and connectors not up tight as they can touch each other real easy.
    Jun 2018
    ny
    218
    I see a lot of trouble abound with cooling and connectors not up tight as they can touch each other real easy. i'LL LEAVE ON THAT NOTE AS I MOST LIKELY WILL t YOU OFF AND NOT INTENDED TO DO SO.
    Norwest, not one thing you have said has teed me off, i am sorry if you felt that way in some of my responses... i come from an rc carpet racing backgroud, and know jack squat about rc boats other than i use the same transmitter as my car...LOL i ask questions to learn...
    i know i need to re shrink those connectors, they arent quite the same as what was on the original esc, i was planning on doing that first thing tomorrow...
    What problems do you see with the cooling? Are my lines too long? Or is that silicone motor sleeve going to give me greif? Lines are run prop wash-motor rear-motor front (pinion/highside)-esc-out the back... Or is a prop wash pickup not ideal? I am still considering converting to a stinger and a rudder...moneys tight right now....LOL
    Mar 2014
    IA
    165
    Crap I hit the wrong button and erased the whole reply! Cooling lines are good and inside diameter of hose is great. Water pickup or prop wash as you have done should be watched to see if water comes out the exit. Let me reread your post again and i'll get back to you, promise.
    Mar 2014
    IA
    165
    Ok, just wrap tape around the connectors. Now as far as change of rudder and etc, let what you have and see how things go.
    Mar 2014
    IA
    165
    Must be tired, can't even spell, lol!
    Mar 2014
    IA
    165
    I hit the wrong key again.
    Jun 2018
    ny
    218
    Norwest, its all good!!!LOL normally i would tape those small gaps but i think i am out of tape right now...LOL i know i have heatshrink left yet... and 10-4 on watching the cooling output!
