Results 1 to 2 of 2
Thread: Blackjack 29 v3. 6s 55mph comfortably.
    Mar 2018
    IN
    64
    Default Blackjack 29 v3. 6s 55mph comfortably.
    I recently posted about batteries.. I ended up getting 2 3s 5000mah 60c...
    First run I shot the flex shaft out of the back along with the prop. I have all stock flex shaft etc.
    I am wanting to build this boat to run a comfortable 55mph since I already have to buy a new prop.
    I was told to get the following :
    https://www.offshoreelectrics.com/pr...od=ose-1390-v3
    https://www.offshoreelectrics.com/pr...ct-ocfhe5mm15S
    https://www.offshoreelectrics.com/pr...-bj29-v3-cable
    and a flex cable saver.
    I have read ALOT on how the 2000kv motor is too much and to switch to a 1500kv motor. But some people I see are running leopard 1900kv, along with the seaking 180a esc. For NOW id like to leave the esc stock, if I can get a comfortably running 55mph on a new motor and stock esc.
    So I am thinking, New Leopard 4 pole 3674 1650KV motor and a x440 prop.. Or what motor that's 1500kv is everyone referring too?
    please shoot holes through my plans. Tell me what wont work and what will.
    Apr 2017
    QL
    1,038
    Forget using a 2000 kv motor on 6s unless your only going to do saw speed runs. really the max kv motor for 6s is 1600 kv,s but the 1500 kv would be a safer option. the 3835- 1500 Dynamite motor is good for your boat to run well on 6s.
