What is the normal RPM for a 39'' catamaran, 30.000 or 40.000 ?
Thank you
Thank you
What is the planned use? What are the desired speeds? Desired run time? Narrow hull?
I don' t want a speed saw monster, I want a fast cat to have fun with friends. I saw videos on Youtube like this one , 2 x 2150 kV on 6S so near 47.000 RPM.
Is this a "standard" or a saw setup ?
https://www.youtube.com/watch?v=X4X7y6biCwA&t=100s
47000 RPM-I would say that’s a definite saw setup. Prop selection would have to be spot on, too big or too great a pitch will draw so many amps you’ll burn out your equipment. Maybe aim for around 30-35000 RPM for a boat that will have some longevity.
Higher power requirements also means less run time. I'd rather have a slower boat and play longer if I'm with friends.
Thank you guys,
I have a set of 1512 1900kV motors, they should be fine with 5S 5000mAh batteries.
