Results 1 to 14 of 14
Thread: Single Genesis upgrade
    Aug 2016
    As
    48
    Default Single Genesis upgrade
    I am going to buy an sinle version of the Genesis from HK.
    Going to order a Tirnigy 200A ESC and us 8s to 12s on that boat.
    Can someone recommend a good motor for that setup?
    Aug 2016
    As
    48
    Any clues?
    Jun 2009
    GA
    595
    Are you going to tear everything off and reinforce it first? Also what 12S is going to fit? A 2200mAh? I have two of these hulls (Daytona 37), and don't see the need for anything above 6S. Even 4S would fine for something a little less demanding.
    Aug 2016
    As
    48
    Haha Maybe a bad idea... Imo i will run 6s or maaaybe 8s (2x4s). So what setup?
    Jun 2015
    Wi
    734
    You may want to read through some genesis thread's. Lot's of info on these.
    Jan 2014
    Ru
    19
    Motor 4092.SSS,2140 kv,for 6s
    Jan 2014
    Ru
    19
    Jun 2009
    GA
    595
    What are you trying to do with the boat?
    Aug 2016
    As
    48
    Just going to do some speed runs..
    what about this setup? https://www.offshoreelectrics.com/pr...-leo4082-combo with 6s?
    Aug 2016
    As
    48
    Tell me the fastest setup on 6s with prop size :)
    Aug 2016
    As
    48
    Jan 2014
    Ru
    19
    443-642 prop.
    FR
    2,096
    Quote Originally Posted by Kram View Post
    This setup is fine imho.
    May 2018
    344
    My first GPS run 82.1mph 6S5000 70-130C TP4050 1950KV ZTW200A ABC 1716 at 42mm.
