Page 3 of 3 FirstFirst 123
Results 61 to 80 of 80
Thread: My TFL Pursuit coming up to speed.
  1. #61
    Feb 2015
    CA
    12
    Can you give me some prop suggestions for my 6s tfl Pursuit. Right now I have a gratinar k45 prop which is 45 mm and I'm getting 47 miles an hour with a hobbywing Seaking 180 V3 and a castle 1717 1650kv motor from an X Maxx. The batteries are lectron pro 5000 3s 50c and I know they're holding me back right now because they're the only thing getting warm. I tried a 42mm CNC 2 blade prop and the speed dropped by five miles an hour. I'm ready to start sharpening and balancing my own props but I'm not sure what probably should start with and money is tight. Obviously I plan on improving the batteries for a higher C rating and maybe going up to a 6,000 or 7,000 milliamp hour
  2. #62
    Oct 2008
    CO
    9,488
    Thumbs up
    Quote Originally Posted by jtthebiggafigga View Post
    question about the motor you are running as the X-Maxx never came with a Castle 1717 motor, but traxxas did make a 1600kv motor for the truck ment to run on 6s and many had issues with it..
    if you do have a real Castle 1717 1650kv motor that would be out of the XO-1 car and those are a beast!
    I run one in a 39.5" mono on 6s running 10,000mAh (heavy setup) and that thing is a ROCKET!
    I think I am running a 52mm prop??
    this small of a boat running that motor spinning a 47mm or even a 50mm prop would be crazy and not have power issues.. LOL
    your packs should be just fine, but remember try not to run them below 3.2v under load and keep around 15-20% min left in the packs after a run.
    shocked you are only seeing 47mph with a 45mm prop, could be it's not metal and flexing.
    lots of racers on these pages who are here to help you along bro
  3. #63
    Mar 2017
    VI
    371
    Octura m447 is a prop you can look into.
  4. #64
    Feb 2015
    CA
    12
    Thank you for the responses everyone! The motor I have I'm 95% sure came out of an X Maxx. I don't remember the dimensions but when I was measuring it to look for water cooling cans I thought it was about the same as the 1717, but I could be wrong. Regardless of the motor size it's not working hard at all because even after I run it for 5 minutes straight the motor still comes back cold as well as the ESC. I will definitely look at the October m447 as recommended. Anybody else have any ideas on other props? I'd really like to see 70 miles an hour on 6s so I can stick with the speed control. I'm not racing, there's no one around here that does boats. Just go on for high-speed passes and enjoying the thrill
  5. #65
    Feb 2015
    CA
    12
    It looks like the m447 only has a pitch of 1.4. When I be wanting something closer to 1.7 or 1.9 bitch for just high-speed passes?
  6. #66
    Oct 2008
    CO
    9,488
    Quote Originally Posted by Speed3 View Post
    Great choice
    http://offshoreelectrics.com/proddet...od=SB-oct-m447
    that X-Maxx motor is not the CC1717 but smaller made by traxxas 1600kv and should work well
    keep in mind running 5mins will warm up your batteries as you are taking them to empty
    yours temps on the motor and esc are good because the props you were using are pretty small for this motor and it's drawing low amps
    this could work well...
    http://offshoreelectrics.com/proddet...od=SB-oct-x648
    many many props choices and this is all part of the fun of FE boats..
  7. #67
    Feb 2015
    CA
    12
    I'm thinking m645 or x645. I have tons of experience with planes and cars and helis so I am somewhat familiar with the diameter/pitch effect on thrust and speed. The graupner 45mm has tons of thrust out of the hole, so if I am just looking for more speed I am thinking it would be best to stick with the same diameter and add pitch. More diameter will reduce slip but the amps go up fast from what I can tell. Am I thinking properly? Also what are the advantages or disadvantages of the M prop versus the X? Definitely going with the prepped props from offshore electric, I wish I had the funds to buy a whole bunch and test but realistically I'm looking at 1 or 2 props a month in my budget.
  8. #68
    Oct 2008
    CO
    9,488
    I was also going to suggest the X645 as that is one of my go to props for racing! had this prop on a stock Lucas Oil boat running mid 50's.
    but won't see the 70mph you were asking for..
    I also have a M645 (de-tonged) prop. little less bite on the leading edge that helps the props spin up using less amps
    my prop of choice in P-Limited Sport Hydro.. mid-upper 50's on 4s with a AQ2030 motor
    will be interesting seeing how that traxxas motor responds with prop changes
  9. #69
    Oct 2008
    CO
    9,488
    Default dasboata
    Also Chris AKA dasboata here at OSE could help you out very quickly in prop selection..
    Prop man who does some good work for many of us who race..
    I own several of his props, they work good!
  10. #70
    Oct 2008
    CO
    9,488
  11. #71
    Feb 2015
    CA
    12
    PM sent to Dasboata, wish me luck!!
  12. #72
    Feb 2015
    CA
    12
    Default Pics added
    Here she is before the first run where it caught some chop and slammed to a stop, ripping out the stock battery, motor and servo mount. Second pic is with all new cnc plasma cut (love my job) mounts for everything glassed in.
  13. #73
    Feb 2015
    CA
    12
    Default One more pic
    One more pic. My buddy did the paint in metallic subaru blue with green that only comes out in the sun.
  14. #74
    Oct 2008
    CO
    9,488
    Nice!
  15. #75
    Feb 2015
    CA
    12
    What timing are you running on the hk motor. I have the same motor but can't find out if it is a wye or delta.
  16. #76
    Feb 2017
    na
    726
    Water time!! My Pursuit 4s back up runs. The two runs I made today were 57mph and 56.8mph. Not a 4s PB but close. The boat picked up right where it left off last Fall an running pretty decent. Thanks to Chris Hoffmann (dasboata)for the Awesome prop!
  17. #77
    Feb 2017
    na
    726
    Default 5s pass (70.4mph)
    My TFL Pursuit gets into the 70mph+ club once again and this time only running on 5s. The boat got 70.4mph by the Garmin and 69mph by the gps data logger. The wind upset the boat just enough to make it get a little out of shape at the end of the run, but you can clearly see by the data logger video that is at the end of the video that the boat got the max speed 1/2 through the pass. Thanks to Chris Hoffmann (dasboata) for the Awesome prop!
  18. #78
    May 2014
    635
    Very nice.
    Would you please list the motor brand, size, and kv, and the prop brand and size specs?
    Ron - The Villages, FL
  19. #79
    Feb 2017
    na
    726
    Thanks! It's pretty much the same setup that I have already PM'ed you the info back in January on when you asked....
  20. #80
    Feb 2015
    CA
    12
    So I'm going all out crazy on my Pursuit. Running 9s 5000 milliamp hour battery and a Chris Hoffmann prop three-blade and a 300 amp ESC. I got up to 74 miles an hour today and it took a skip super fast and submerged and touched the bottom. Luckily the damage isn't too bad . I reinforced the hell out of this hull after its last crash on 6s which nearly ripped the hatch off when it pulled out stock battery mounts and motor mount. I have the CG at about 33% and the strut neutral as well as the trim tabs. Anybody have any suggestions has for maximum stability at high speed for a mono? I'm going to try moving the batteries forward quite a bit as right now they're backed up almost touching the motor and I figured a few degrees of down angle on the strut would be a good idea too.
    https://youtu.be/uwLScdq40BU
    Thanks for the help everyone this is pretty darn fun
