I ran my Etti 150A (non-bec) controller yesterday in my DF33 on 4S with a 1515/1Y. It ran well, and the motor and ESC were virtually cold after each run (I used an X442 and an M445).
One thing I noticed though, the throttle is not very smooth (used to run a B125 in this boat), and full throttle seems to come in at about 1/2 trigger movement. The water was choppy yesterday, so it made the boat quite difficult to drive. Radio is a Spektrum DX3, and the throttle is set to 125% (I needed 125% to get full power with my Hacker 70, so I assumed this is the same as 100% in other radios).
Is there any way to set the throttle curve or calbrate this controller to match my radio?
Also, what timing should I be running on the 1515/1Y? The setting for 2-4 pole motors seems pretty low, has anyone tried bumping it up on a similar set-up?
Thanks,
Scott
Thanks,
Scott
