If you put either abc prop on you will have to dial it in again because it will blow over with the abc props because of the bow lift they will produce. If your looking for speed with what you have try this:
Sharpen rudder
Shorten rudder 1/4” at a time
Knife edge the bottom of the rudder
Eliminate slack in steering
Polish your flex shaft
Use motor oil mixed with graphite powder as your flex lube
Shorten power wires as much as possible
Add a cap bank
I guarantee you’ll go over 70 if you do all these. Do one at a time though to see which one makes the most difference and you’ll learn something too in the process.
