Results 1 to 5 of 5
Thread: Prop recommendation for Aeromarine Conquest
    Jul 2011
    19
    Default Prop recommendation for Aeromarine Conquest
    Hey everyone recently put a castle 2028 780KV in and old Gas hull i had planning on running it on 10s i tried a very light gas prop on 8s (Prather 260) and its clearly wrong not getting very good performance wondering where i should start and what type of numbers for speed i should be aiming for
    thanks Chris
    Dec 2010
    3,117
    try some where around 57 MM the prather has to much transom lift ! Ill see what I have in ABC props for you PM me if interested
    May 2017
    VA
    562
    6717/3
    IMPBA 20583
    Way too much prop for that motor on 10S! It may work fine on 8S, but the 10* rake ABCs have too much lift to work the best.
    May 2017
    VA
    562
    And that Sir is why you are a master of FE! That’s a good prop for my gas conquest, wasn’t really thinking of crossover difference.
    IMPBA 20583
