Page 1 of 2 12 LastLast
Results 1 to 30 of 37
Thread: twin AC R42 build
Hybrid View
    Jun 2012
    ny
    1,135
    Default twin AC R42 build
    Hello, I tried to sell these motors and ESC'S with no luck. so I'm going ahead with this build inspired by Shawn ( Sirlash) lol. Converting this from gas build that never got finished. I have 2 neu 1515 1650 KV MOTORS AND 2 Etti speed controls plan on 5s per side. center mounted counter rotating props. and skag struts any input would be appreciated
    ON
    2,913
    Eugene
    With 5S per side in that large hull, you may need more then a 120A ESC.
    I run a 36" Avenger twin for racing Oval and Offshore classes
    6S per side
    Trunigy marine 180A-V2's
    TP4050's -1575KV motors
    45mm- props
    https://www.facebook.com/groups/1675...1255439039918/
    Larry
    Mar 2011
    BC
    7,630
    Haha, I am planning on using my Etti 120’s as well but with a pair of TP 4050 950kv’s on 10s which I’ve had around forever.
    And Gene I have logs stating 190 amps on BlownAway. Mind you those are Castle 1717’s and I think that boat is on the heavy side.
    Mar 2009
    OH
    1,585
    1515,s are way too small. Maybe 1521 per side or best 1527 per side. That’s a big boat. I built one with a 3080 Lehner and one with a 2030 NEU. 70 mph boats. I now run a Top Gun with duel Pletts and a dual Flier 300.
    AZ
    8,010
    Howard is right, the motors are too small with too high a Kv for 5S. The props will be too small for decent efficiency. I raced this hull on 10S with a single Neu 2215 and x462 prop, it needs some power to perform well.
    Jun 2012
    ny
    1,135
    thanks everyone for the advice looks like I'll have to look for some different motors.
    Jun 2012
    ny
    1,135
    How about the TP 4070 4Y 1090 KV would that work?
    Apr 2017
    QL
    1,038
    I thought you could go up to atleast 1600 kv,s running 6s in oval race trim, so you would think a 1600 kv motor running 5s would be fine.
    Nov 2015
    BC
    276
    Quote Originally Posted by meangenesracing View Post
    For what it's worth, in my dual powered 50" H&M Supercat XL I run the same motors, TP 4070 1090Kv on 8S/side with a X447's and it moves the big hull easily with decent runtime, for more speed I'll run reduced (50mm) X457's and motors easily turn them too. For esc's I'm running MGM 25063's but certainly more esc than is required but the headroom is nice.
    Jun 2012
    ny
    1,135
    Quote Originally Posted by Lone-Wolf View Post
    can you tell me what batteries and how many mah per.
    battery thanks, geno
    Nov 2015
    BC
    276
    I run Revo 70C 5000ma packs.
    Mar 2011
    BC
    7,630
    Just 1p per side Steve?
    Jun 2012
    ny
    1,135
    diden't know Revo made 8s packs
    Jul 2011
    ID
    1,292
    Yeah, that sounds about right and should be just fine in that boat. If you set it up as a twin with each motor running 5s , you're only looking at 29,280 rpm's per motor
    Mar 2011
    BC
    7,630
    Geno, what size props are you aiming at? I am running 447’s on BlownAway with the 1717’s(1577kv) on 6s and that gets me 70’ish miles per hour. I am getting 4mins runtime but that is with 8,400-8,800mah per side.
    I would just like to try a lighter setup.
  16. #16
    Jun 2012
    ny
    1,135
    I do have a set of 447"s but could get bigger ones also
  17. #17
    Mar 2011
    BC
    7,630
    I just ordered a pair of CNC 50mm/2’s in bronze to try on that one. So as soon as they arrive I’ll toss them on and get back to you.
  18. #18
    Jun 2012
    ny
    1,135
    ok, I'm thinking that's the direction I'm going with the TP 4070 motors. I've been wanting to try the TP motors. thanks again
  19. #19
    Jun 2012
    ny
    1,135
    yup, that's my plan 8mm shafts. thanks for all the help
  20. #20
    Jun 2012
    ny
    1,135
    got these in the mail today they should do the trick. 4070 1090 KV
  21. #21
    Nov 2015
    BC
    276
    NICE! Now you're cooking with gas!
  22. #22
    Jun 2012
    ny
    1,135
    got some work done this weekend. motors are a little forward than I would like but had a hard time with stuffing tubes being to short and flex cables with to much binding. I'm sure I can make up for it with battery placement. just waiting on my full hatch to set cog.
  23. #23
    Mar 2011
    BC
    7,630
    Oh I didn’t think of that with the motors on tunnel. Maybe ESC’s over Motors if need be. That hatch is tall for the gas engines.
  24. #24
    Mar 2011
    BC
    7,630
    So how far from transom did you get the motors Geno?
    And if it helps progression my hatch weighs 18oz and it’s cg is at 13.5” from the front hatch lip opening.
  25. #25
    Jun 2012
    ny
    1,135
    1 foot center of motors to transom.
  26. #26
    Jun 2012
    ny
    1,135
    How does this happen ? I was programming esc plugged into 8s and smoked controller not even running motor. tha other esc is getting warm just plugged in
  27. #27
    Mar 2011
    BC
    7,630
    Ok Geno, I plugged 8s into all three that I have sitting here. No heat developed. Soooo, I guess I gotta ask where you got them? New faulty?
  28. #28
    Jun 2012
    ny
    1,135
    bought new here from Steven. I hooked the other one up again and it's not getting warm now. maybe I had a loose connection I will keep an eye on it thanks again Shawn
  29. #29
    Mar 2011
    BC
    7,630
    That is not right.
  30. #30
    Feb 2008
    GB
    2,731
    Were both BECs conected?
