Results 1 to 17 of 17
Thread: Swordfish data logger help
    Mar 2013
    VA
    54
    Default Swordfish data logger help
    I downloaded the software for the Swordfish ESc, but I keep getting a message saying to select a port. It lists 8 ports. I tried them all, and just keep getting error messages saying "wrong port". Can anybody help?
    Thanks,
    Fred
    Oct 2017
    AZ
    67
    What model esc do you ?
    Aug 2017
    OZ
    577
    Quote Originally Posted by fred685 View Post
    Thanks,
    Fred
    Have you checked your Device Manager to see which port the software is on? You need to select that port.
    Mar 2013
    VA
    54
    Yes, but my device manager doesn't show anything about com ports.
    Dec 2013
    138
    Did you get it figured out? What model Swordfish is it?
    Oct 2015
    313
    Run the program as Administrator
    Dec 2013
    138
    I am on com port 4 and it recognizes the ESC and I can set parameters, log set up, gear and number of poles. I am running as administrator. When I click download log the blue bar advances and finally says
    C:\program files (x86)HiFei V6.0\2018-10-29.0.dat was not found.
    Dec 2013
    138
    Quote Originally Posted by SlickZERO View Post
    I have one working but still no data retrieved.
    Any ideas how to get the data?
    Dec 2013
    138
    Sorry, I thought I said. They are the Swordfish X+ 220A
    May 2014
    494
    Hi Bret,
    The software will not complete the download process without being run in Administrator mode. So put your mouse pointer on the shortcut, then left click and choose "run as administrator". It will complete and display the graphs.
    The Villages, FL
    club site - http://castawaysboatworx.club/
    Dec 2013
    138
    I plug in the wire from the esc to the computer. I right click the desktop icon and select "run as administrator." A pop up says: "Do you want to allow this app from and unknown publisher make changes to your device?" I click "Yes". Then the software opens up. I click open device and in a couple seconds it displays the esc in the rectangular window on the bottom. From there I can change the parameter setting.
    I click "Show the record". No esc is shown in the white rectangular box. I click "Open device". After a few seconds the white box still shows no esc. (It show it on the first screen as I said above). I click "Upload record data" anyway. A little blue bar advances from left to right. Sometimes quick and sometimes real slow. Then pops up
    Note: Unless I run as administrator it won't let me set the parameters.
    Sep 2013
    IN
    851
    on the logger configuration screen did you set the ESC to record at "X"per second intervals? I think I remember a few having no default set and thus nothing was recorded.
    Dec 2013
    138
    Quote Originally Posted by trigger View Post
    Yes, actually tried a couple different settings.
    Jan 2017
    Ql
    4
    I am having issues with mine also. The esc does not seem to register at all. I dont have all the boxes on the screen either. I cannot click to go to parameter settings. To even get to the parameter settings i need to hit tab a few times and then enter. I have run the program as administrator also.
    Aug 2018
    Ky
    99
    Quote Originally Posted by Mrlocky View Post
    I plug in the wire from the esc to the computer. I right click the desktop icon and select "run as administrator." A pop up says: "Do you want to allow this app from and unknown publisher make changes to your device?" I click "Yes". Then the software opens up. Then I click on the options across the top and nothing happens!!! This is very frustrating. I down loaded the software from the included disk and have been trying to make it work as Administrator. NOTHING...any more suggestions?
  16. #16
    Dec 2011
    oh
    30
    Default a fix to most issues with this esc
    n #1 download may have been errored its a r.a.r file has to be OPENED WITH A RAR UNZIPPER
    ALLL OF THIS ADMINIS. TALK may be at best a 20% solution
    please try this buy a new programing cable so far that is a fix the cable is a p.o.s. just try it!!!!!!!!
  17. #17
    Sep 2013
    IN
    851
    Here is a link to the cable example.
    https://forums.offshoreelectrics.com...ight=ESC+cable
