Results 1 to 13 of 13
Thread: Miss Geico twin
    Default Miss Geico twin
    I need to clear room on my shelves and since I’m onto a little bigger boats I think this one would be a lot of fun for someone. I built it from a bare hull I picked up locally. It runs on 4s and is a real good one on 5s. I put Proboat 1800kv Motors in it powered by Seaking 120’s (V1 I believe). The ride surfaces were modified to prevent some of the ‘tripping’ in corners. Build thread is here: https://forums.offshoreelectrics.com...n-G&highlight=
    And the last vid and time it ran was here at the 4 minute mark:
    https://youtu.be/
    I am looking for $400 ARTR (unless you have a Spektrum then I can include Rx.
    Mmm, sorry about the shots. I’ll try and Remedy them. So the hull got a good inlay but there was a couple hairline cracks when I got the hull. I have the pic here. I think I will go over the bottom again this weekend so she is all good again.
    can't see the video , doesn't come up . How long and wide is the boat ?? what hull is it ??
    Quote Originally Posted by nmnorth View Post
    I had this one bookmarked...
    HPR C5009 Mystic twin, Genesis 37, Zelos 36 twin, Voracity 36, Miss Geico 29 V3, King of Shaves P1, Mini Zonda 27, Miss Budweiser 1/12, Delta Force 26, Offshore Infinity, Stealthwake, Vac-U-Tug Jr
    I’ll take it for $400 is that shipped? I’m in ohio , I do have a spectrum radio
    Yes I can ship it for that. It is a V1 Proboat Geico. I would like to go over the bottom as long as you are not in a panic. That was 5s in the video BTW. And the other spot on the hull was between the sponsons in the classic seam spot. It was addressed in the rebuild. I can get a pic in a bit before we seal the deal.
    And thanks Ryan!
    Ok sounds good
    What 5s battery’s were you running , how many Mah? How much fits in hull
    I have run 3300mah but it is a little loose and light. The 4000mah’s I had were great. Nothing special for cells just a local brand. I’ll see if I can get the size. It was an easy fit.
    Here is the front. But it is all beefed up inside. I just did not want to mess with the paint on this one.
    That’s fine , would you include the bind plug for the receiver I can bind my radio to your receiver , just put it in bind port . I’ll cover Paypal fees PM me your pp info , just pm me shipping info when ready , thanks Bill
    I have a spare bind plug Bill. Will include. PM incoming
    Figured I’d stick this on here, I boxed her up well.
    Looks like a fun boat!
    Knowledge is knowing a tomato is a fruit. Wisdom is knowing not to use it in a fruit salad.
    PB BlackJack 29 / AQ Motley Crew / Tenshock Mini ECO / Phil Thomas Stealth
