I was wondering if anyone can help me out with this???? I bought a used (nearly new) BJ26 brushless from someone on this site and I took it out for the first time today and the thing kept cutting out after about 1/4 throttle or less.
Out of the water I could rev it to full throttle, but everytime I put it in the water it would lurch forward and stop, then when I gave it gas again it would lurch forward then stop again. It was very annoying. I tried putting in different packs and it did the same thing.
I also tried shutting everything off and unplugging the packs. Also, I changed the throttle trim settings on my remote. Nothing helped.
I know there is a rev limiter so you can't over rev it on land, but in my case it seems to be reversed because I can rev it out of the water but not in the water
The previous owner had programmed it to run on lipos, but I used the programming module to change the settings back to NiMH. I'm really confused as to what is going on
