Results 1 to 17 of 17
Thread: ML RSX380 FE Outrigger (First Attempt)
    Aug 2016
    187
    Default ML RSX380 FE Outrigger (First Attempt)
    Hi all,
    This would be my first build and I'm looking to put together a material list for this ML RSX380. Found the kit and all suggested hardware. what I don't have is a shop or garage filled with all the little things to put it all together ie: glues, resins, epoxy's, sanding materials ect. What are you guys using for what and what are things I should be adding to the list that I would need? Ive read through a few wood builds (Bob Zola, MarkF, Luck as a Constant and Mooine) very helpful but these guys make it look easy, which it might not be for me ! Given there is some extra room in this model for batts I am thinking a 6s setup, I read the plans call for a 40X82 motor so I'm thinking a 1521, 1577Kv 1Y, I'm not racing, sport running right now but you never know. Looks to handle speed and turns very well and I would like to push it a bit, what do you guys think for target speeds, motors, props and getting it all balanced out? Any advise or tips would be much appreciated!
    Thanks,
    Ryan
    Aug 2016
    187
    Here is a start, let me know if I'm missing anthing or suggestions you may have. This is all basic stuff to most but for someone like me that is just starting from nothing it’s definitely a learning process. Maybe this list and build will be helpful to others that are also attempting their first one.
    Hardware:
    Speedmaster Sport 21 Hydro Rudder
    Large Speedmaster round bottom / hydro Strut
    40 size Turn Fin: https://www.mojoracingproducts.com/
    K&S 8131 1/4" stuffing tube
    Zippkits 5/16" Solid Carbon Boom Tube Rods or equivalent pn# zip-5603
    Zippkits Long Boom Tube Sleeves- 5/16" pn# zip-3586
    Zippkits Boom Tube Collars- 5/16" pn# zip-3480
    Servo Mount: https://www.offshoreelectrics.com/pr...prod=ose-80090
    Water outlet: https://www.offshoreelectrics.com/pr...prod=aero-2011
    Servo Linkage: https://www.offshoreelectrics.com/pr...d=mbp-CE225452 https://www.offshoreelectrics.com/pr...od=mbp-KA-3025
    Servo: Spektrum S6230 Digital
    Flex shaft assembly: https://www.offshoreelectrics.com/pr...?prod=ose-1190
    Drive dog: https://www.offshoreelectrics.com/pr...prod=oct-oc6dm
    Motor:
    Neu 1527 .75Y 1640kv and water jacket
    Mount: https://www.offshoreelectrics.com/pr...rod=ham-101580 or https://www.offshoreelectrics.com/pr...rod=tfl-523b63 or other?
    ESC:
    Starting Prop:
    Material List:
    CA glue
    Epoxy - West system 105/206
    Titebond III wood glue
    Sealer - West system 105/206
    Sanding blocks 80 and 150 grit
    200\400 grit sand paper
    Bondo
    Fiberglass cloth strips
    Carbon fiber inlay: https://www.jamestowndistributors.com or EBay
    Clamps
    Aluminum to use as backing for rudder, turn fin and strut?
    JB weld or Gflex 650 and 406 thickener to mount the sled and seal the stuffing tube? Suggestions?
    Jan 2013
    Ga
    1,358
    Neu 1527 1.5d or .75y
    Neu 1530 .75y (extra $45 competition wind) or
    Tp 4070 3y or 5d
    Aug 2016
    187
    Thanks, Would there be any issue fitting the 1527 in? and in terms of efficiency, between the 1.5d@1500kv and the .75y@1640kv what would offer a more efficient setup?
    Jan 2013
    Ga
    1,358
    1527 will fit no problem if the tp4070 will and that is what Mark is using. Far as efficiency should be fairly close as the kv is not much of a difference.
    Aug 2016
    187
    Quote Originally Posted by jim82 View Post
    Alright good stuff, That takes care of the motor, Thanks Jim!
    Jan 2013
    Ga
    1,358
    West system 105 and 206 hardner you can use for everything. When you are ready to seal just use some denatured alcohol to thin it a little more
    Aug 2016
    187
    Okay, should it be thinned out a bit to apply the carbon inlay as well or leave as is for that?
    Aug 2016
    187
    Curious, I’ve seen some pictures (not of a finished boat but just for reference) of 2 5000mah 6s packs fitting in the back. Would this be to much weight to be running 2 6s packs in parallel? Wait those must have been 3s packs, 6s packs are huge! Nevermind
    Jan 2013
    Ga
    1,358
    I don't actually own one of these just giving suggestions of what I would do. The battery part someone who has one or if you want to wait till you get that part finished then decide for yourself .On the inlay no it is thin enough for that.
    Aug 2016
    187
    Got it, what rigger do you have there your profile pic? Size?
    Jan 2013
    Ga
    1,358
    That is a Jae 33
    Aug 2016
    187
    That is a Jae 33
    Nice, that’s a good kit. It’s also convenient there is a option to pretty much get everything needed in one shot, hardware and all. Hopefully I’ll get my order in on Monday if I get everything figured out. Thanks again
    Jun 2015
    Wi
    734
    If you're looking for steering linkage Steve sells 3mm rod that is threaded on one end for a 3mm aluminum ball end. My go to now for any linkage.
    Aug 2016
    187
    Quote Originally Posted by Mxkid261 View Post
    Thanks, no doubt a good option I’m also keeping my eye out for some fixed length rods threaded on both sides that I can use the ball ends on.
    Aug 2016
    187
    In regards to the .187 flex shaft assembly, better to make one or buy it already made? Any difference in strength?
    9,400
    Buy....
