Page 1 of 3 123 LastLast
Results 1 to 30 of 70
Thread: Conversion from Dumas 55 KV to Center Console Cigarette w/ Twin new X-Cat Outboards
    Jan 2016
    ma
    97
    Default Conversion from Dumas 55 KV to Center Console Cigarette w/ Twin new X-Cat Outboards
    Hi everybody, Just bought this NOS Dumas 55 inch KV on ebay and thought it would be a good hull for a center console conversion with the new X-Cat outboards that OSE is now selling. I will post photo's and info as the build progresses. Here's the first step so far . Cut deck off and add a glassed in transom 3/8 thick. Drill drain hole, Install stainless well nuts for engines,alter Stern to look like the real 38' Cigarette. Install water pick-ups in bottom. The reason I chose this hull is cause it resembles it's real counterpart and I'm looking for for scale appearance and scale speed.These hulls in the 1980's were real dogs to get over 50 mph with a 90 OPS , couldn't get them loose so I figured it would be a good choice for a scale build. This will be a very detailed build with a lot of niceties. So revisit often and you can watch the transformation. Enjoy Chip[/ATTACH]IM002769.jpgIM002772.jpgIM002770.jpgIM002771.jpg
    Jan 2016
    ma
    97
    P.S. This is what were shooting for as an end result (Photo enclosed) . Istead of 3 outboards at 250 hp each. 2 outboards at 400 hp each ROS X-Cat 400'smaxresdefault.jpg Heres a pic of the hull before removing the deck s-l1600 (6).jpg
    Jan 2016
    ma
    97
    Apr 2017
    MT
    155
    Nice project. Can't wait to see things as you progress
    Jan 2016
    ma
    97
    Here's a photo of the others , but they are only 40 inches long and smaller this one will be a total of 60 inches when completed. IM001810.jpgIM001757.jpgIM001757.jpgIM001811.jpgIM002356.jpg
    7,629
    Nice Chip, I’ll follow along with your mad skills.
    Shaen
    Apr 2017
    MT
    155
    DANG!!!!!!!!!! You do some great work. The detail on some of those and the craftsmanship just awesome!!!!
    Jan 2016
    ma
    97
    Well,,, Today made a template for deck floor,and cut it out of cintra ,then cut the hole for radio/ esc/batteries box . This hole will determine the foot print for the center console. The box will be the exact size as the hole and rise 1 3/4 inches above the deck. Any water that gets on the deck will run around the box and drain out the scuppers that will be installed in transom that will be above the water line in the stern . The floor will be sealed all the way around the hull and box making a air compartment below deck (totaly unsinkable) More to come Chip
    Jan 2016
    ma
    97
    Today. fabricate radio box out of cintra. Next step will be the routing of all wires and water tubes under deckIM002777.jpgIM002776.jpg
    Dec 2015
    La
    550
    Where do you get the cintra your working with?
    Jan 2016
    ma
    97
    A few photo's of wiring and water tubes
    Jan 2016
    ma
    97
    Palco Plastics in Whitman Ma. is where I get the Cintra. 44.00 bucks for a 4'x8' sheet. Dumas uses it on all there wood model boats as sub planking now because It's lite, water proof, easy to cut and sand,Buoyant (floats), and paint and CA glue sticks to it like a rock It's great stuff,and the sheet will do 10 boats.lol
    Dec 2015
    La
    550
    Thanks.
    Mar 2012
    Qc
    186
    I just found your threat , i'm an addict to outboard , i follow you for sure ! I am building one with OB myself ( Smaller ) .
    Jan 2016
    ma
    97
    Hi, Today I fiber-glassed all framework, Fed all wires and cooling tubes and glued the deck down.IM002781.jpgIM002782.jpgIM002783.jpg IM002784.jpg Now ,let dry overnight and seal the floor with aquarium silicone tomorrow.
    Jan 2016
    ma
    97
    Oh forgot ,Yesterday I added a couple of risers in the stern took all day, refer to real boat picture and then model before and after . If you look at the real boat you can see that it has a step up towards the stern.
    Mar 2012
    Qc
    186
    What is the size of the props you put on the OB ?
    Jan 2016
    ma
    97
    Really don't know yet . Trial and error with plastic ,then get a good set of stainless props
    Jan 2016
    ma
    97
    Today 4/18/18 seal floor and console radio boxIM002777.jpg Later in day cut interior sides and install rod holder boxes , more to come Chip
    Mar 2012
    Qc
    186
    Quote Originally Posted by boatsareus View Post
    Thank's , i read on the OSE website that the OB can have up to 60mm , after i saw your 4 blades , i check for a 60 mm 4 blades , i did not find one under 65 mm , that's the reason i ask ! Thank's for your answer and keep your good work !
    Jan 2016
    ma
    97
    Ok ,yesterday afternoon I fabricated the inside walls and put gaff , boat hook and rod holder boxes in walls. This afternoon I installed the walls ,fabricated a piece for the front wall and brought the entire wall height to 1/8 inch above the deck. I'm all done for today and about a week cause I need to finish a customers boat . Ive been waiting for the paint to cure and harden like a rock before handling it. Check back , stern and console nextIM002778.jpg IM002779.jpg
    Dec 2015
    La
    550
    Nice!!
    Jan 2016
    ma
    97
    Took a 2 hr break today and made the stern. Starting to look like the real one above, lol
    Jan 2016
    ma
    97
    Built the door access to engines and swimming todayIM002783.jpgIM002784.jpgIM002782.jpg
    Jan 2016
    ma
    97
    Picked up a set of Trim Tabs from OSE, the newest ones he carries , really nice and the perfect size !!! I like to get all my holes drilled before I paint. IM002785.jpg
    Jan 2016
    ma
    97
    Jan 2016
    ma
    97
    Jun 2009
    2,536
    Wow!
    Jan 2016
    ma
    97
    Made some seat cushions ot of 1/2 Balsa and gave them 2 coats of fiberglass resin and made the drivers lean post . Now seat's need to be painted with satin finish colors and satin clear coatIM002798.jpgIM002798.jpgIM002799.jpgIM002800.jpg
    Jan 2016
    ma
    97
    Seats all painted , just need touch-ups and then satin clear-coat IM002801.jpgIM002802.jpgIM002803.jpg
