Fitting the hatches:
The front fiberglass hatch comes with pre etched lines on the long sides. I scribed over these with a pencil, as well as the front and rear cut points. The carbide wheel Dremmel tool made easy work of cutting the fiberglass. The front of the fiberglass hatch needs some retention tabs. I made the 3 you see from some plywood scraps. I ground the wood thinner with a sanding block to form a step. This now fits perfectly under the front deck.
The rear hatch is just a piece of plywood. Minimal fitting was required.
Attachment 158631Attachment 158632Attachment 158633Attachment 158634
