Results 1 to 11 of 11
Thread: Soldering #8 wire
    Jul 2015
    Ca
    635
    Default Soldering #8 wire
    Just got a 200 amp flier with 8 gauge wire ,will use 8 mm connectors ,
    Will a regular solder station do the trick? That’s big wire,my buddy has one of those mini torches if that’s what it take ,input please ,thanks ,
    Mar 2015
    CA
    1,261
    Why don't you try it and find out?
    Jul 2015
    Ca
    635
    I was and having a tough time but I usually get help with this stuff so I was planning ahead ,
    Dec 2010
    NY
    2,591
    Quote Originally Posted by MG1234 View Post
    I have a 80 watt iron with a 3/8 tip and I also use the pencil torch
    Jul 2016
    3,018
    750*F and wide enough tip will work fine, if your solder station has adjustable heat settings
    Jul 2016
    NY
    359
    Butane torch and a vice work great. Takes about 2 minutes
    Apr 2015
    TX
    199
    I used to always struggle soldering heavier wires until I picked up one of those 100w/140w soldering guns. I think weller is the brand and you can get them at most any hardware store very reasonable i.e. lowes, homedepot, etc.
    Feb 2008
    GB
    2,400
    I was once warned by a local brushed ESC manufacturer against using a torch to solder ESCs, as friction between the gaseous fuel and air in torches can build up a static charge, and there is no practical way to ground them to dissipate it.
    Paul "tug Killer" Upton-Taylor, Cat lover.
    FastElectricBoats.co.uk
    Ga
    5,179
    TOY BOAT RACER
    IMPBA Dist.13 Director
    IMPBA 19887CD
    NAMBA 1169
    Aug 2010
    uk
    2,880
    I was also warned about using a torch on sensitive electronics as NativePaul states, this was from an electronics guy that knows far more than I ever would about electronics. I to use the Weller 80w iron that Doug highlights for larger jobs, this iron really does hold the heat & is a breeze on larger soldering jobs.
    Jul 2015
    Ca
    635
    One thing I learned I didn’t have the right tip ,I tried my weller gun and it worked better because of the wider tip,my solder station only had the sharp one ,got a selection of tips ,a micro torch and its all good ,the ESC has 8” leads on the battery and motor so with that and the anti spark ground I’m hoping the static will be dispelled,it really is 15 sec to solder an 8 mm connector, just like soldering pipe,anyway got a ton of work done with the right tools ,thanks guys ,
