Page 3 of 3 FirstFirst 123
Results 61 to 86 of 86
Thread: Recovery boat.. What does everyone use
  1. #61
    Apr 2018
    10
    Im using a KMB jet boat on 4s with a dynamite 36 series motor and a pvc fork type catching unit mounted on the front
  2. #62
    May 2014
    636
  3. #63
    Mar 2018
    IN
    64
    Quote Originally Posted by zooma View Post
    That looks pretty simple to make.. how much?
    Sent from my SM-G955U using Tapatalk
  4. #64
    May 2014
    636
    I guess about $20 for the 1/2" PVC pipe, tees & elbows, and noodles. But, I had a 15 size airplane outrunner motor, 3 cell batt & servo. I bought a Turnigy 40 amp ESC so I could have reverse. So, about $100 in the electronics.
    Ron - The Villages, FL
  5. #65
    Aug 2011
    252
    I'm planning on building a rescue boat, if you don't mind providing more information on your build. I'm not too familiar with outrunner setup and prop, just wondering what KV motor you bought and size of prop I should get.
  6. #66
    May 2019
    MA
    23
    Swamp Dawg air boat. $49 HK. It works ok now that I have a 3 blade prop.
  7. #67
    Aug 2016
    Mi
    20
    I use a highly modified Cajun Commander air boat for my rescues.
    9BDA3823-5792-4590-91CE-E72B8B6B19BB.jpg6D3DE2A1-4505-4CD0-9ECE-3946A9BF43AB.jpg[ATTACH=CONFIG]165768[/ATTACHp]4CA817DF-E0E9-4DB0-85C7-E5DB1940D822.jpg4CA817DF-E0E9-4DB0-85C7-E5DB1940D822.jpg
  8. #68
    Jul 2007
    MD
    198
    ProBoat has a new 30-inch tug that comes with recovery arms:
    https://www.horizonhobby.com/product...Ue4D5Q7Zeq4w5A
    Revolt 30, River Jet, Southampton Tug, Outcast 6S BLX, 8ight-E, Ten-SCBE, 22 2.0.
    '09 Miata.
    Ibanez basses and guitars. Mapex drums, Zildjian cymbals.
  9. #69
    Sep 2017
    409
    Wow talk about over priced!
  10. #70
    Apr 2020
    702
    Quote Originally Posted by skeeler View Post
    I thought long & hard about this. I even almost "pulled the trigger". But, I think I've decided to stick with my current collection of 3 'part-time' rescue boats (ProBoat Shockwave w/ much lower kV motor & PVC tube rescue platform, TFL Jet Boat, and my just-acquired Tenshock Mini Eco), as all three can be used as 'rescue' boats, as well as for 'pure enjoyment'.
  11. #71
    2,913
    Here is mine.
    LJ
  12. #72
    Sep 2020
    MA
    118
    Air boat. DIY for around 150$.
  13. #73
    Oct 2016
    pa
    476
    traxxas blast with a pvc and noodle setup . went with the blast because it uses prop steer and steers better at low speeds then a boat with rudder steer . can also fit a 5000 mah lipo in there so plenty of rescue time . 20191010_192342.jpg
    volantex vector pro ,proboat veles 29 , traxxas spartan, hobbyking/tfl pursuit ,ft009 with rescue rigging
  14. #74
    Sep 2020
    MA
    118
    That's a good looking setup! Question about the Traxxas Blast - does it have a reverse? I currently have the DIY air boat, and the Neptune cheap RC boat from Harbor Freight tools which has a custom PVC harness. One problem with the Naptune is that it has forward only, and no reverse!
  15. #75
    Oct 2016
    pa
    476
    no reverse .you can however change the esc on the blast to get reverse .i never found it necessary
  16. #76
    Sep 2020
    MA
    118
    Thanks for that information. In my experience in a recovery boat reverse is a must. I have ended up on the shore and wasn't able to back up die to no reverse... Also, of the disabled boat is far away, where it's hard to see, scooping the disabled boat becomes a challenge. Having reverse helps. All of the above made me build an air boat, which has reverse.
  17. #77
    Apr 2020
    702
    Quote Originally Posted by Nick1979 View Post
    Also, if the disabled boat is far away, where it's hard to see, scooping the disabled boat becomes a challenge. Having reverse helps.
    I'm definitely in agreement on a rescue boat needing reverse if it's using a review platform. Regarding rescuing a boat Russia "a distance", that's why I installed an FPV camera onto the canopy of my primary rescue boat, as well as a display monitor onto that boat's Tx.
  18. #78
    Quote Originally Posted by jake414 View Post
    Getting my revolt 30 here soon hopefully..
    For the time being I'm going to use a fishing pole with a tennis ball, but eventually want a CHEAP recovery boat.
    So this has brought me to the used cheap boat market and ebay.
    this boat will ONLY be used as a recovery boat, doesn't have to be fast or anything. Looking for 2.4ghz (obviously) and atleast 5 minutes of run time.
    this def isn't hobby grade : https://www.ebay.com/itm/PX-16-1-16-...0AAOSwGHJaZ~aY
    BUT it has a lipo battery and seems to be maybe a deans plug. and its fairly big?
    https://www.ebay.com/itm/Genuine-Fei...gAAOSwWxNYq7ng
    this also has a lipo.
    My thinking is, these small lipos can be had very cheap so it would be easy to get more run time..
    Thoughts?
    I just got the new ProBoat BlackJack 42 and I was looking for a nice recovery boat.. After doing around a month or so of research, I decided to go with the -
    Feilun FT011 65CM 2.4G Brushless RC Boat that is a water cooling system. Plus it has a pretty cool nose guard where I can hook on my recovery system that I have in mind...
    Feilun FT011 Review
    http://<a href="https://www.youtube....m-NLq6gH-k</a>
    BJ42'' / Miss Geico 36'' / TFL Hydro 35'' / Retrieval boat 30'' Tug
    Make sure you check out my Youtube channel -----> shorturl.at/ntFQ7
  19. #79
    Oct 2016
    pa
    476
    keep in mind that during a rescue you will be moving pretty slow most the time ......lining up the boat......pushing back to shore........the motor will not get much water cooling effect at those speeds .
    thats one the reasons i went with a brushed motor boat . motors are bigger and can dissipate their own heat better and some have heatsinks .
    most tugs are brushed motor or twin brushed motors for the same reason . just something to think about . you could add a water pump to pump cooling water thru the system at low speed .
  20. #80
    May 2014
    636
    Using an outrunner airplane motor and SeaKing ESC without water cooling. Current is too low to matter.
  21. #81
    Apr 2020
    702
    I'm about to take my ProBoat Shockwave "rescue" boat in a new direction, and looking for some thoughts on what I'm proposing. The 'plan' is to take it from "one of my 3 part time rescue boats" (the other two are a TFL Jet Boat, and a Tenshock Mini Eco), and torn it into "my only full time rescue boat" (this making the other two 100% "pleasure use").
    Right now, I've got a dual-rudder, with the water line from one rudder cooling the motor, and the water line from the other rudder cooling the ESC. The ESC (which will remain) is a SeaKing 120A, the motor is a Leopard 3650 1350kv, and the prop is the stock 42mm plastic prop. The 'problem' has been keeping the motor & ESC cool, as the slower speed prevents the water pickups from pushing (pulling?) enough water through them lines. Remember that the stock motor is 2000kv.
    So...here's what I'm looking to do. First up is to replace the 1350kv with a 1050kv motor. Next to install two 370-based water pumps, to keep water flowing through the system no matter the boat's speed (even when the boat is motionless). Third is too replace the stock plastic 42mm 1.4 pitch (or, if it 1.6?) prop with a larger diameter (and possibly lower pitch) prop. To start in I'll be testing the plastic Octura 1245, 1250, & 1450 2-blade 'chopper' props. I would have preferred to include some 3-blade props, but I couldn't find any plastic 'chopper' style props in the 42-46mm range. While I'll (probably) eventually go with a metal prop, I prefer testing using the plastic props, as they're a LOT lower on price.
    For those who know boats better than I do, what are your thoughts...on the motor choice and/or my planned use of water pumps and/or my current prop choices? Obviously, the purpose isn't 'speed'...it's "go slow, but with a lot of torque". The dual-rudder setup allows turning equally well in both directions, even when pushing the rescue platform w/ rescued boat.
  22. #82
    Default Here is how I will be building my recovery boat system...
    Here is an example of the recovery system that I will be creating for my
    Feilun FT011 boat
  23. #83
    Apr 2020
    702
    The latest "downgrades" to my Shockwave 'rescue boat' are complete. Installing the Leopard 4074 1050kv it Shockwave proved a little more difficult that expected. I had to take the trusty Dremel to the black (shiny) plastic piece that the mounting tray is attached to, sure to the larger motor diameter. Once that was complete, I moved into swapping the stock strut & flex cable with the OSE Cable System w/ 3/16" strut. After that, I installed the two 370-based water pumps (just in front of the transom). 'Home testing' was completed in my usual "testing facility", aka the bathtub.
    As the 1040kv motor is, obviously, slower than the 1350kv motor I had tried using, and a LOT slower than the Shockwave's stock 2000kv motor, I knew I needed to go with a larger prop (stock, if I remember correctly, is either 39mm, or 41mm...honestly, I didn't measure it). I selected the OSE 3-blade 47mm...which, as some of you probably know, is a 'cleaver' style prop, and not really appropriate for what is now essentially a (fast looking) "tug". On top of that, with the dual-rudder, to 47mm turned out to be sightly larger than would fit (when the rudders are full-left, or full-right). So, out came my trusty Dremel (again). Not only did I make the prop smaller in diameter (44mm, having removed 1.5mm from each blade), but I also changed it from a 'cleaver' prop, to a 'chopper' prop.
    If all goes as I'm hoping it will, I will be doing a full-on "working" test tomorrow. Just hope I don't forget the temp gun (which I have forgotten in the past). If all goes well, I will consider my Shockwave as my permanent 'full-time' rescue boat. That's what I am...or, will be...using as my rescue boat from now on.
  24. #84
    Default Zipkit Tug Recovery boat for the Black Jack 42..
    ProBoat BlackJack 42 Ripping Laps on 8s on a new #Dasboata Prop incl. Recovery Zipkit TugBoat for the rescue...
    https://www.youtube.com/watch?v=q-ATYkj6lc0
  25. #85
    9,402
    Quote Originally Posted by HammertimeAZ View Post
    I dont take my boats to the biggest lakes in town but I always carry a light weight spinning fishing rod with a weighted Styrofoam bobber. Fingers crossed, Ive been able to get myself out of most pickles. I know its not a boat but it is one hell-of-a retriever!
    What line weight do you use? Fishing rod is always a great go to if it's not too far out.
  26. #86
    9,402
    What timing would you recommend for a recovery boat like yours? I have a 600KV 5055 outrunner on 4S.
    I just bought all the tubing yesterday and I have everything but pool foamies and a prop so far.
    I'm looking forward to getting out and testing with less worry of boat loss.
