Page 1 of 3 123 LastLast
Results 1 to 30 of 86
Thread: Recovery boat.. What does everyone use
Hybrid View
    Mar 2018
    IN
    64
    Default Recovery boat.. What does everyone use
    Getting my revolt 30 here soon hopefully..
    For the time being I'm going to use a fishing pole with a tennis ball, but eventually want a CHEAP recovery boat.
    So this has brought me to the used cheap boat market and ebay.
    this boat will ONLY be used as a recovery boat, doesn't have to be fast or anything. Looking for 2.4ghz (obviously) and atleast 5 minutes of run time.
    this def isn't hobby grade : https://www.ebay.com/itm/PX-16-1-16-...0AAOSwGHJaZ~aY
    BUT it has a lipo battery and seems to be maybe a deans plug. and its fairly big?
    https://www.ebay.com/itm/Genuine-Fei...gAAOSwWxNYq7ng
    this also has a lipo.
    My thinking is, these small lipos can be had very cheap so it would be easy to get more run time..
    Thoughts?
    AZ
    8,010
    Cool
    Before you go too cheap remember that a recovery boat needs to be dependable. It needs to have enough power to push/pull a boat against wind and/or current at a decent speed (or it may run out of battery). It needs to be very maneuverable to be able to “attach” itself to the dead boat.
    Another requirement is range. Most cheap boats have short ranges, the boat referenced says it’s range is 100 meters, but who really knows? You may end up with two dead boats. Plus it apparently has no throttle, just forward and stop. You may be better off buying a used, better quality boat. Just some things to consider.
    https://www.amazon.com/Storm-Engine-...ews/B0153R9IY8
    Apr 2017
    QL
    1,038
    Yes Fluid is exactly correct there. i made up a aero prop design rescue boat and it was both under powered and was also very hard to turn tight. you need good power and good maneuverability for a successfull rescue boat. plus don,t run out of radio range.
    May 2017
    OK
    1,464
    I use this setup...
    Mar 2018
    IN
    64
    I use this setup...
    What is that
    Sent from my SM-G955U using Tapatalk
    May 2017
    OK
    1,464
    Quote Originally Posted by jake414 View Post
    What is that
    It’s an Hydro-Net, a leave catcher for a swimming pool. I upgraded it to a longer range radio and a dual mixer ESC for the DC motors in the dual outboards. Also put a LiPo 3S battery in it, it had a NiCad originally. It works good! It nest the stranded boat quite well..
    May 2017
    OK
    1,464
    I think the most effective rescue boats have dual props with steering mixing. You’ll want to turn on a dime, it’s not easy getting on the dead boat. Wind and eye sight make it a bit of a challenge.
    Jan 2017
    Ma
    170
    I have a canoe, 12volt battery, an a trolling motor. I go for a boat ride. Sometimes I catch a fish or two along the way, two hobbies same pond twice the fun.
    Sep 2013
    IN
    853
    Where in Indy are you?
    Mar 2018
    IN
    64
    Quote Originally Posted by trigger View Post
    Noblesville fishers area
    Sep 2013
    IN
    853
    Our Indy admirals fast electric season starts soon (April). Come check out a race, lots of fun running with other people. We run at 465 and Binford blvd area.
    https://forums.offshoreelectrics.com...s-RC-Boat-club
    Feb 2017
    na
    726
    An AquaCraft Atlantic II tug works good for me. Even if you loose the recovery float in an attempted rescue it can still push the boats in with the Bow that is wrapped in semi sticky rubber. See it in action below. For my bigger boats the AquaCraft Fire Rescue boat is my choice.
    Mar 2018
    IN
    64
    Ok those are valid points. I need to find a 20"+ boat and make a pvc floating deal to hold the boat and push it.
    Mar 2015
    CA
    1,262
    9E3CB6D9-E7B3-4212-B749-83EDE952EA44.jpg1AD9520D-5942-4BB8-8C6C-4A416B47E2E7.jpg2400F625-A9BE-4416-A8D9-BF2CE7A9BE95.jpg
    Zippkits tug boat is pretty nice, super cheap and easy to put together. Took me 1-2 days to put mine together. It was like $50
    Thinking maybe to put a sort of an extendable "trolling" rod on the back - like a sturdy antenna of some kind with a dull treble hook/line
    I was considering the fire glass tugboats from hydromarine.de or Mhz powerboats before but they were easily $300-400 after Euro to US dollar conversion and shipping.
    Unless you go route of overkill --
    Mar 2018
    IN
    64
    Quote Originally Posted by dmitry100 View Post
    What tugboat from zip is that?
  16. #16
    Sep 2011
    BA
    296
    Also doing some tests and using parts that I was finding recovering.
  17. #17
    May 2017
    OK
    1,464
    Golfito, that’s a nice configuration. But it doesn’t need speed... The prop should be deep, not even close to surface riding. I would put two motors in it, for dual counter rotating props. Then use a very low pitch set of props, to deliver good pushing power. The motors can be 560 brushed type for a cheaper build. There are dual motor tank or bot ESC’s that have the mixing built into them, so you can turn the boat 360 degrees on its center axis. But if they ever make a rescue boat race class, I think you’ll have them all smoked!
  18. #18
    Jan 2016
    1,464
    I've had floating U tube for my rescue boat and it works fine until I tried just connecting a fishing line for fly fishing. It floats so you can see it and at the other end are some bobbers with barbless treble hooks and this works faster and more efficient for me. I just run the boat with the fly line quickly to the stranded boat and circle around it a few times and bring it in. With some good motors on the rescue boat you can get there quite fast and it brings it in pretty quick. I like the idea that I can get to the stranded boat fast just in case it was caused by a crash or a severe crash where water is getting in through cracks or a loose canopy. Then I can get it back to shore quickly. Also it's not so cumbersome as with the rescue boat with the U foam configuration . .I call it the goal since it's shaped like the football goal posts. But whatever you choose it's always good to have a rescue boat of some kind.
  19. #19
    Sep 2013
    NJ
    151
    Vac-U-Tug with a length of floating fly line and a few floats. It can pull my GP400 against the wind. SLOWLY..but it can do it.
  20. #20
    Nov 2008
    Ql
    3,169
    Quote Originally Posted by Navherc130 View Post
    Guys.
    To make things really easy on the rescue boat's motor,ESC,& battery, have it tow the line out & around the stricken boat, with the line attached to a fishing rod & reel. Put the transmitter for the rescue boat down in a safe place, & reel both boats in with the fishing rod.
    And there you have it. "The catch of the day".
  21. #21
    Mar 2015
    CA
    1,262
    my tug is running a 2pole 1700kv castle motor on 3 cells using a 30mm 3blade prop - can this generate too much heat from the partial load, or should it be fine? currently it has a seaking 180 on it but from my experience a bit of partial load can easily burn it to a crisp. i'm putting a water pump into it for extra safety. Kind of want a bulletproof dependable setup here... nothing worse than having 2 boats that need rescuing
  22. #22
    Apr 2017
    QL
    1,038
    you might want to use a cheaper and lower amp esc than the 180 for your set up.
  23. #23
    Aug 2012
    AZ
    261
    Sorry for the long video, but it's as real time as it gets....... Love my recovery vessel
  24. #24
    Jun 2011
    ct
    826
    Quote Originally Posted by Tbauer View Post
    thats fine for when the boat is right in front of you. what happens when it's 150 yards away?
  25. #25
    Aug 2012
    AZ
    261
    Quote Originally Posted by urbs00007 View Post
    I have a 5.8 video transmitter, works bitchin
  26. #26
    Mar 2017
    or
    236
    nice.....
    Im building an FPV recovery barge, I have river currents, tides and big vegetation along the sides of the river at my house so the dead race boat could actually be out of site and you might not be able to get behind it to retrieve the broken boat if it gets in the vegetation, so I am engineering a crane and grappling hook with a forward and reverse 30lb rock crawler winch ...my fpv cam is a mini cam with built in video transmitter running on a tiny 4v battery all tucked inside a tiny Polaroid cube camera waterproof housing and I have a set of Fat Shark goggles to use from my racing drone.
    Now living on the columbia river I have boats and kayaks to retrieve the dead RC boats but this is more fun than paddling out to a dead sinking boat while cursing, I also have running lights, yellow flashing lights the camera will be mounted on a servo so it can turn to any angle. The only thing I havent come to terms with is powering it, I do have a couple spare outboards I may use.
  27. #27
    Jan 2016
    1,464
    Quote Originally Posted by MadProps View Post
    nice.....
    Very interesting. . .would like to see this to completion and see it tested.
  28. #28
    Aug 2012
    AZ
    261
    That looks sweet I have all the navigation lights and spotlights as well cuz I like to boat right at nightfall. I would recommend the outboards based on my personal experience they offer the most maneuverability and they're a lot easier to mount it different places on the recovery vessel
  29. #29
    Aug 2012
    AZ
    261
    I forgot to mention you can't see it on the video cuz it's in the water but don't forget to add something underneath like netting to recover your boat. As it fills with water it starts to sink- or if it's upside down a lot of times you will drive up and over the boat- so by adding netting to the bottom if that happens The netting will stop it from going underneath or sinking. Just another trick I learned through trial and error
  30. #30
    Sep 2017
    MI
    409
    Vintage Latrax Cigarette hull from the late 70s early 80's with first gen Pro Boat Shockwave 26 brushed 540 running gear. I made a cradle out of 3/4 inch PVC and pipe insulation that this pushes to sweep up the other boat. The boat was given to me from a friend on a R/C car forum but all the electronics were fried, I figured I should use it some how. It works good because the plastic is pretty heavy and it has a wide beam. And the new steerable out-drive makes it maneuverable.
